Just home from Dyno.
Old May 28, 2005 | 04:37 PM
Phat_GSR's Avatar
Default Just home from Dyno.
this was at 15psi, started leaning out at the top with the 440's and i didn't have time to switch over to my 1000cc's.
going back next week with the 1000;s in and race fuel going to 30psi.
I was happy enough with this for now though.
Old May 28, 2005 | 04:38 PM
non-VTEC's Avatar
Default Re: Just home from Dyno. (Phat_GSR)
NICE..........what turbo?
Old May 28, 2005 | 04:43 PM
Phat_GSR's Avatar
Default Re: Just home from Dyno. (non-VTEC)
peak boost kit with a t3/t04R
Old May 28, 2005 | 04:46 PM
non-VTEC's Avatar
so how does it drive on the street?
must be an animal
Old May 28, 2005 | 05:08 PM
Adriano's Avatar
What was the base fuel pressure on those 440 injectors?
Adriano
Old May 28, 2005 | 05:24 PM
DENCIO's Avatar
Default Re: Just home from Dyno. (Adriano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adriano &raquo;</TD></TR><TR><TD CLASS="quote">What was the base fuel pressure on those 440 injectors?
Adriano</TD></TR></TABLE>
like he said...
Old May 28, 2005 | 05:40 PM
rocket256's Avatar
Default Re: Just home from Dyno. (DENCIO)
Were that injectors maxed out? 440 should have only been about 370-380hp. But never the less. Good #'s!!!
Old May 28, 2005 | 05:54 PM
Phat_GSR's Avatar
Default Re: Just home from Dyno. (rocket256)
drives nice on the street actually.
as for the fuel, the pressure was at I beleive 40 with the vaccum lin on so around 44 with the line off.
yeah thats what stop us from going any higher was the injectors and the tuner had a wedding to go to so we couldn't stay late.
11SEC CIV's Avatar
whats your set up?
Old May 28, 2005 | 06:26 PM
Tad's Avatar
Tad
Default Re: Just home from Dyno. (12SEC CIV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12SEC CIV &raquo;</TD></TR><TR><TD CLASS="quote">whats your set up?</TD></TR></TABLE>
found this under his name
Old May 28, 2005 | 08:01 PM
seen4ever's Avatar
Default Re: Just home from Dyno. (Tad)
wow, i had 105% duty cycle for my 550cc injectors at 355whp, i can't imagine pushing 440s over the 400whp mark. nice looking curve there.
Old May 28, 2005 | 10:04 PM
Phat_GSR's Avatar
Default Re: Just home from Dyno. (seen4ever)
yeah the guy was saying that the pump was cutting out but i thinbk it was maxing the injectors
my set up is.
Je pistons
eagle rods
darton sleeves
itr cams
pep valve springs and ti-retainers
manley valves
jg edelbrok intake manifold
str fuel rail
440cc rc injectors
-8 fuel line from the pump
aem regulator -6 retun
peak boost turbo kit with a t3/t04R
F.A.S.T standalone ecu,
msd 6al
Old May 29, 2005 | 12:15 AM
Makdaddynuge's Avatar
nice man, can't wait to see the numbers on race gas
Old May 29, 2005 | 04:58 AM
Rod.'s Avatar
Default Re: (Makdaddynuge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Makdaddynuge &raquo;</TD></TR><TR><TD CLASS="quote">nice man, can't wait to see the numbers on race gas</TD></TR></TABLE>
same here
Old May 29, 2005 | 05:02 AM
FredoSP's Avatar
i bet its fun to drive on the street
Old May 29, 2005 | 07:53 AM
DLB1994's Avatar
Default Re: Just home from Dyno. (FredoSP)
edit: lol sorry didnt see it
Old May 29, 2005 | 07:55 AM
Tchleung's Avatar
Default Re: Just home from Dyno. (DLB1994)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DLB1994 &raquo;</TD></TR><TR><TD CLASS="quote">wheres your base fuel psi ?, 80psi? </TD></TR></TABLE>
Take the time to actually read the thread....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phat_GSR &raquo;</TD></TR><TR><TD CLASS="quote">40 with the vaccum lin on so around 44 with the line off.</TD></TR></TABLE>
Old May 29, 2005 | 08:00 AM
DLB1994's Avatar
Default Re: Just home from Dyno. (Tchleung)
i dont think he know what size they are , theres no way 44psi of fuel with 440cc on any standalone with out some kinda fmu to make 400+ whp
Old May 29, 2005 | 08:16 AM
Tchleung's Avatar
450's from what I've seen usually go up to high 300's. That could explain why he sais he's leaning out up top
Old May 29, 2005 | 08:18 AM
HitEm'Up's Avatar
I cant believe those injectors made it thru that! Either way nice numbers Good Luck with the bigger injectors
Old May 29, 2005 | 08:23 AM
DLB1994's Avatar
Default Re: (Tchleung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">450's from what I've seen usually go up to high 300's. That could explain why he sais he's leaning out up top</TD></TR></TABLE>
theres no way 450cc can makw high 3's with base around 40-44psi
i have maxed out many 550cc at 350whp range with base 38-42psi
somethings not adding up!
Old May 29, 2005 | 08:35 AM
ITSME4G63's Avatar
nice numbers man, **** if that picture doesnt say "No expense spared" than I dont know what does.
Old May 29, 2005 | 08:44 AM
Lei Siew Long's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seen4ever &raquo;</TD></TR><TR><TD CLASS="quote">wow, i had 105% duty cycle for my 550cc injectors at 355whp, i can't imagine pushing 440s over the 400whp mark. nice looking curve there.</TD></TR></TABLE>
My 550cc injectors maxed at 343 hp. As others have said, I believe the injectors are a lot larger than 440cc.
Old May 29, 2005 | 08:49 AM
SOHC_MShue's Avatar
wow that motor looks really similar to my friend's motor . They got the same cam gears, same intake manifold, a similar looking fuel rail, and a similar oil pan.
Old May 30, 2005 | 08:27 PM
SiRkid's Avatar
Default Re: Just home from Dyno. (SOHC_MShue)
NICE! great to see soem local speed. hopefully ill see this thing at the strip this year!
