Just did a Compression Test.=(
Ok I just a compression test on my Junkyard Z6. I put it in my car and after a few complications I got it running. Well yesterday it started to run like ****. Missing at idle and then it starting to overheat. And every once it a while it will blow white smoke. Headgasket I was guessing??? Well the #'s from the test
1-150
2-170
3-210
4-150
And while testing #3 there ended up being water in the hose going to the gauge. ****. And then while testing #4 water was spitting up out of #3. Bad headgsket cracked sleeve? Any ideas?
1-150
2-170
3-210
4-150
I see a rebuild in your near future...yes...its becoming clearer...you wallet will beome much lighter.
sorry dude. best case..head gasket. worst, cracked sleeves, melted pistons, smashed ringlands.
Thanks for the input. This sucks I just bought that damn motor after blowing up the y8 I had in there..Have not even drove it 100 miles....
i don't think you melted a piston because the numbers would be a WHOLE lot less... when my buddy melted a nice hole in his piston (turn the nice round piston into a 3/4 circle haha), the numbers were 0, on the other piston that was bad, there was only a small hole that was melted, the results were the same. O.
Since your car overheats, im close to 100% positive you have a blown headgasket. Your car would be billowing smoke and probably not running if you cracked a sleeve.
-ryan
-ryan
Yeah I am going for just a Blown headgasket. I will proably tear down both the Z6 and the Y8 I got and get the Y8 head resurfaced and put it ont the Z6 block. ARP Headstuds too!!! What is the deal with using copperspray on the headgasket?
im quite scared to even do a compression test on my engine.... i have a feeling imma find some low #'s. headgaskets already going bad, leaking/burning coolant.
good luck in ur case. if u got the Y8 out... might as well rebuild it....
Damn.. sorry to hear that..
hope it's just a headgasket..
I'm going for comp. and leakdown test tomorrow...
wish me luck.. I hope everything is ok..
hope it's just a headgasket..I'm going for comp. and leakdown test tomorrow...
Yeah I am hoping it is just the headgasket. I guess I will find out this weekend. Also where is the best place to find ARP head studs?
turbosivtec
May 24, 2009 04:33 PM
Louie_EM1
16
Mar 16, 2004 05:58 PM
