JRSC and throttle bodies
Old Dec 19, 2002 | 04:50 PM
1strdtko's Avatar
Default JRSC and throttle bodies
Which will bolt on without a hassel and what size would you recommend?
Old Dec 19, 2002 | 05:03 PM
CRVRX's Avatar
Default Re: JRSC and throttle bodies (1strdtko)
SOHC or DOHC ???
If it's a B series every body and there brother makes a thottle body , You need to go with as big as you can. The blower is pulling air so you need as little resistance as possible, the down side is the Jackson "s" pipe is only 60 mm so It will need some grinding to match it up.
Old Dec 19, 2002 | 06:54 PM
1strdtko's Avatar
Default Re: JRSC and throttle bodies (CRVRX)
Will the Eriks racing TB work?
Old Dec 19, 2002 | 07:02 PM
CRVRX's Avatar
DOHC, Yep !
C_Rock77
Apr 1, 2009 05:18 AM
DeDonDeRosa
Apr 21, 2004 12:52 PM
morepoop4u
Sep 7, 2003 10:01 PM
NCSTIdriver
Oct 22, 2002 07:53 AM
B18Flip
Sep 16, 2002 03:02 PM
