JRSC Problem
Old Sep 18, 2002 | 07:22 PM
TrymsGSR's Avatar
Default JRSC Problem
I have a jrsc on my gsr and recently its been acting weird. When I start boosting with the peddle mashed it starts bucking, but once it gets into vtec it stops and pulls normally. The weird thing is after a while it completely stops and runs fine. I've gotten colder plugs and that didn't help, so I bought thicker plug wires and that stopped it for a few days. Now I'm having the same problem. I have no idea what I could be. It seems like an ignition problem to me so the only thing left to do is get a new cap and rotor. What do you guys think. Any help is greatly appreciated. TIA.
Old Sep 18, 2002 | 07:41 PM
TrymsGSR's Avatar
Default Re: JRSC Problem (TrymsGSR)
ttt
Old Sep 18, 2002 | 07:56 PM
avividmemory's Avatar
bucking? what do you mean by that?
Old Sep 18, 2002 | 08:07 PM
TrymsGSR's Avatar
Default Re: JRSC Problem (SpoolinLS)
I don't know how else to explain it..........it starts jumping forward like I'm gettin on and off the throttle real fast
Old Sep 18, 2002 | 08:09 PM
like wheel hop? or not? whats your current setup, with internals ie clutch and **** too
Old Sep 18, 2002 | 08:10 PM
Mase's Avatar
whats your fuel setup
Old Sep 18, 2002 | 08:12 PM
TrymsGSR's Avatar
pretty much stock except for I/E. Clutch is stock. It only has 50000 miles on it and the blower's only been on for 6000 miles. it's not wheel hop the car just starts jerking.
Old Sep 18, 2002 | 08:13 PM
TrymsGSR's Avatar
Default Re: JRSC Problem (CDooMe2)
fuel set up is stock except for the fpr that came with the kit
Old Sep 18, 2002 | 08:14 PM
Mase's Avatar
inline pump or intake pump?
Old Sep 18, 2002 | 08:15 PM
TrymsGSR's Avatar
stock fuel pump, just the fuel pressure riser that was included in the kit. I don't think it's detonating. I can't hear it and the plugs look pretty tan.
Old Sep 18, 2002 | 08:17 PM
Mase's Avatar
you wont be able to hear detonation while driving. My guess its something fuel related, the FMU's suck ***, go w/ hondata and bigger injectors.
Old Sep 18, 2002 | 08:22 PM
TrymsGSR's Avatar
what I can't understand is why it will do it for a while and then stop after I've been driving for a while, and then after it sits for a while the **** starts again
Old Sep 18, 2002 | 08:23 PM
Mase's Avatar
who knows, it could be a change in ambient temp, humidity, and maybe the fmu is just getting stuck wide open.
this one is beyond me...im out like the fat kid in dodge ball!
Old Sep 18, 2002 | 08:27 PM
TrymsGSR's Avatar
it's pissin me off..oh well I'll look at it more tomorrow.. thanks for your help
Old Sep 18, 2002 | 08:29 PM
Mase's Avatar
no prob, hope you fix the problem
Old Sep 18, 2002 | 09:02 PM
CRVRX's Avatar
Check the fuel pressure while under boost, it should be around 80lbs under 6/7 pounds of boost. Check the plugs too, gap them at .028 and try that, try the basics , fuel filter, fuel pump, plugs, cap and rotor.
Good Luck!
Old Sep 19, 2002 | 08:17 AM
TrymsGSR's Avatar
Default Re: JRSC Problem (CRVRX)
I'll pick up a cap and rotor and regap my plugs today and see if that helps. Any one else have any ideas?
Old Sep 19, 2002 | 09:51 AM
Holden's Avatar
I strongly disagree with CRVRX. Fuel pressure under full boost should be at least 90psi. With the JR FMU, it is probably at a nice safe 100psi.
Also, gap your plugs to .038", not .028".
Old Sep 19, 2002 | 09:54 AM
Sonny's Avatar
Default Re: JRSC Problem (Holden)
To add to Greg's sentiments, you cannot run that kind of fuel pressure with the stock pump! Honda fuel pumps have an internal bypass valve that prevents them from pushing more than 75 psi of pressure. Upgrade that pump!
Sonny
Old Sep 19, 2002 | 09:58 AM
TrymsGSR's Avatar
Default Re: JRSC Problem (Sonny)
so you guys think it's definitely fuel? What pump do you suggest?
Old Sep 21, 2002 | 06:04 PM
Heavy Pee's Avatar
Check your motor mounts!
Old Sep 21, 2002 | 06:29 PM
Sonny's Avatar
Walbro GSS-342.
Sonny
Old Sep 21, 2002 | 07:21 PM
p0gi's Avatar
Maybe you should try replacing the ignitor.
Old Sep 21, 2002 | 08:22 PM
SiRkid's Avatar
Default Re: JRSC Problem (p0gi)
change that SHITTY jr FMU to at least a cartech one!
Civic92Turbo
Mar 10, 2007 04:27 PM
SamC
Jul 1, 2004 11:53 AM
preludesh012001
Sep 16, 2003 04:47 PM
MartyMarGSR
Sep 6, 2002 08:30 AM
euroturbo-R
Jul 19, 2002 09:31 AM
