jrsc only making 5lbs
Old Aug 18, 2009 | 07:05 PM
Mr. Chainsaw's Avatar
Default jrsc only making 5lbs
alright, so i put my car together last week. it's stock gsr block, b16head with double coil springs, titanium retainers blah blah blah, and gsr cams. took it to the tuner, i have the 8lbs jrsc crank pulley and he said it's only making 5lbs on the dyno. I really have a hard time believing i am having belt slip issues, i made sure they were tight AND straight. I can't wrap my head around how i'm missing 3lbs of boost. anyone have some input?
Old Aug 18, 2009 | 09:30 PM
Default Re: jrsc only making 5lbs
and fyi, i am using the stock pulley on the nose of the charger, and the jrsc crank pulley, so if i am thinking right, i should be 8lbs, any help would be appreciated, i've tried researching pulley size to boost numbers, but can't find anything with the jrsc pulley, just b20, b18, blah blah blah
Old Aug 19, 2009 | 05:59 AM
david974's Avatar
how old are you belts? or mileage on these
Old Aug 19, 2009 | 08:42 AM
PrecisionH23a's Avatar
Get a new belt and tension it.
Old Aug 19, 2009 | 04:39 PM
brand spankin new belts
Old Aug 19, 2009 | 05:12 PM
I CRX I's Avatar
get a boost gauge or borrow one from a friend to measure the boost yourself. also, make sure the map sensor is reading it right, assuming he is reading the boost from the ecu. if the map sensor is not reading the boost correctly then its boom for your motor.
Old Aug 19, 2009 | 07:45 PM
well right now its only making 180hp, so 5lbs sounds right
Old Aug 27, 2009 | 05:09 PM
got a new boost gauge and its dead on. can't figure this out
Old Aug 28, 2009 | 12:58 AM
91jdmhatchback's Avatar
could there be a leak at a gasket? or is your by pass valve leaking?
Old Aug 28, 2009 | 07:49 AM
nope and nope. mercury is too good to have a leak
Old Aug 28, 2009 | 10:01 AM
what?
Old Aug 28, 2009 | 10:52 AM
MONSTERek4's Avatar
i tune a complete stock gsr on 5 psi made 208. whp on 102 degrees he is on stock pulleys and map sensor was reading 5 psi! too
Old Aug 28, 2009 | 10:59 AM
i only suggest checking over all gaskets. because when i first turbo'd my dd i had a bad t-body gasket which did not show n/a. after fixing this i gained 3 lbs boost. so you never know.
Old Aug 28, 2009 | 05:36 PM
my vac is too good to have a leak. my TB gasket could be leaking its *** off and not affect how much boost i make (supercharged roots style) i'm sitting at 23-24 vac at idle anyway, if i had a leak it wouldn't be anywhere near that.
Old Aug 30, 2009 | 08:39 PM
i put the gsr crank pulley on, and i gained .5 - 1 psi
Old Sep 9, 2009 | 04:40 PM
fyi. the kid had a 4.2 snout pulley, not the 4.0. so with the Jackson pulley (which is actually a smaller diameter than a stock gsr pulley) I was making less boost. with the GSR pulley it made 6.5 on the dyno and fell off to 6 up high which is normal.
wunfstgsr
Feb 23, 2009 04:30 AM
mrx
Jul 12, 2006 06:30 AM
MADEINIRAQ
Nov 21, 2003 05:24 AM
fredtoast
Nov 27, 2002 11:09 AM
dariusz
Apr 14, 2002 05:57 PM
