JRSC ITR exhaust setup
Old Jul 15, 2011 | 01:31 AM
Woody.'s Avatar
Default JRSC ITR exhaust setup
Hello I'm building an 84x89 ITR and plan to JRSC. I'm going to run a 3" exhaust and want it to be quiet, unlikely I know.
So far this is what i'm thinking:
3" mandrel bent piping
2x Vibrant Ultra Quiet resonators
Car Sound/Hytech high Flow cAt
80mm Apexi WS2.
I know I'm going to restrict flow a little, but vibrant claims to be straight though design. So how restrictive will this setup be, and estimatedly how quiet should be? Near stock?
My next question is do skunk 2 pro 1 perform well with JRSC? I have them because I was going to use them n/a but I picked up a JRSC at a good price.
Old Jul 15, 2011 | 10:31 AM
Woody.'s Avatar
Default Re: JRSC ITR exhaust setup
TTT
Old Jul 15, 2011 | 12:17 PM
Veris's Avatar
Skunk2 pro 1 are too aggressive. GSR/ITR combo is the best cam setup, but either pure GSR or ITR setup would be better then the skunk2s.
I have no idea how loud it'll be. I run a cat and twin loop exhaust and mine setup is stock quiet until I open it up.
Old Jul 15, 2011 | 12:31 PM
ryguy2588's Avatar
I had an Apexi WS2, but it was the 60mm version and the 80mm version is straight through. Mine was very very quiet with a cat. Yours will probably be a little louder but shouldn't be too bad just because of the straight through design of the 80mm WS2. Pick up a set of CTR or 00-01 ITR cams.
Old Jul 15, 2011 | 01:24 PM
Woody.'s Avatar
I currently have ITR cams in the head, but I just bought skunk 2 pro 1 and was planning to swap them in when I put the head on the block. Then I came across a JRSC for super cheap and couldn't resist.
If my exhaust make no sound at all, I would be happy. Im not a fan of a loud exhaust but I need the larger exhaust for performance. And I know a 3" quiet exhaust is rare.
Old Jul 15, 2011 | 02:18 PM
Spawne32's Avatar
http://www.solo-performance.com/mufflers.php
i use a PLM b series narrow header, and run 3" resonators
Old Jul 16, 2011 | 08:22 PM
Woody.'s Avatar
Also - will 310 RC injectors be sufficient or will I need to upgrade to a higher cc?
Old Jul 17, 2011 | 08:14 PM
wunfstgsr's Avatar
Loved
Community Favorite
If your running about 5-7 psi 310cc injectors are good over that go with 440cc injectors.
i ran the sk2 pro 1 on a high comp gsr motor at 6psi 2.5 inch buddy club spec 3 catback some other simple mods and made 230hp, since the comp on the motor was high the cams helped bring static compression down a bit. check my first jrsc build started on pg 1. check my second jrsc setup a few pages after hit 285hp on a race setup.
https://honda-tech.com/forums/appearance-build-threads-122/c-street-sleeper-want-feedback-comments-lots-pics-%2A%2A%2A-2556604/
Old Jul 21, 2011 | 09:09 PM
Woody.'s Avatar
I didn't see the 285 setup. Thanks for the post tho. Lots of information
Old Jul 22, 2011 | 11:09 AM
Woody.'s Avatar
How do I increase my b16 JRSC that comes with 6 PSI to 8 psi?
Old Jul 22, 2011 | 05:10 PM
Woody.'s Avatar
This is currently what I'm thinking.
84x89 ITR
10.5:1 Compression
550cc injectors
Stock 99-00 SI B16 JRSC. I know its an m62 but what size nose pulley. I'm looking to go from 6 to 8 PSI, not much more than that. Too hot in Texas. Looking for insight on how to jump to 8 PSI safely/effectively.
Old Jul 22, 2011 | 05:47 PM
DDTECH's Avatar
For SC's cam choice should involve a good sized intake and a bigger exhaust.. SC create a ton of exhaust gases, which makes the cam choices between the s/c and turbo setup completely different..
a gsr intake and ITR exhaust cam would be a good bases to start with.
Old Jul 22, 2011 | 09:50 PM
Woody.'s Avatar
That's the cam combo I'm going to use. What's a good aftermarket cam setup? And how do I jump my psi to 8? I figure 10 psi will have detonation issues.
Old Jul 23, 2011 | 04:15 AM
Natural Aspirations's Avatar
You must change pulleys to increase PSI on a JRSC. IF you have time call ASP
http://www.aspracing.com/index.html
YOU HAVE TO CALL its not on their site, they make the best pulleys for the JRSC but there is a 6-8 week lead time.
Old Jul 23, 2011 | 07:32 AM
Woody.'s Avatar
I dont have 6-8 weeks. I mean I do but id have to retune. I don't want to run the CRV pulley because I hear a lot of belt slippage occurs. And the endyn stepper pulley will put me at about 10-11 psi.
Old Jul 23, 2011 | 07:39 AM
Endyn stepper is inferior to the ASP design and normally increases boost preside 2 psi
MVM is another stepper pulley manufacturer.
Old Jul 23, 2011 | 07:40 AM
Calling ASP to get details on lead time is your best option.
Old Jul 23, 2011 | 08:30 AM
Woody.'s Avatar
Just called them. 4 weeks wait. That's a really long time.
Old Jul 23, 2011 | 08:38 AM
Spawne32's Avatar
http://www.pulleyboys.com/store/cata...ulley-p-1.html
these might work for you
Old Jul 23, 2011 | 10:25 AM
Those are for k-series
Old Jul 23, 2011 | 10:26 AM
Spawne32's Avatar
should still be the same type of key, just has an extra rib i believe
Old Jul 23, 2011 | 12:32 PM
Woody.'s Avatar
So I'm back to square one on how to increase boost from 6 psi to 8 psi.
Old Jul 23, 2011 | 02:11 PM
I suggest you LOOK in the JRSC thread...
Old Jul 23, 2011 | 06:44 PM
Woody.'s Avatar
I have looked. Through 100 of pages. The B16 comes with 6 PSI. With a CRV pulley I should jump up to about 8, however CRV pulley on a b16 will have slip issues correct? Next is the endyn pulley. They have 3 left in stock, and will jump me to 10 or 11 PSI. That is much too high.
I have seen nothing on an LS pulley though. And am unsure about a GSR
Do you have a link to what psi different pulleys will produce?
Old Jul 23, 2011 | 06:51 PM
Woody.'s Avatar
I did find this:
http://ftlracing.com/tech/honda/jrsc_pulley.html
Which says a B16 with a LS pulley will produce about 8.6 psi. However, I have a 2.0L motor and not the 1.6. Does this alter the accuracy of this information? I'm nearly positive I have a 4.2 nose pulley.
Also - I just noticed the kit may have came with a UR alternator pulley. How iwll that affect PSI
