JRSC GSR Dyno Graph
Old May 11, 2002 | 10:40 PM
sgT's Avatar
sgT
Default JRSC GSR Dyno Graph
stock motor, 6psi, or is it 7? i can never remember
This one was rather strong wouldnt you say??
Old May 11, 2002 | 10:57 PM
DragII's Avatar
25 Year Member
Default Re: JRSC GSR Dyno Graph (sgT)
<-----happy he went turbo.
nice torque though, almost VW like.
Old May 11, 2002 | 10:58 PM
sgT's Avatar
sgT
Default Re: JRSC GSR Dyno Graph (SuperDragII)
lol
who will wish he went with b18c instead of b16a
Old May 11, 2002 | 10:59 PM
DragII's Avatar
25 Year Member
hehe....I'm sure your right
Old May 11, 2002 | 11:08 PM
Arturbo's Avatar
Better than steak
25 Year Member
lol
haha!!
Well the jrsc does what it says it'll do. It doenst promise the high hp that turbo does, but Im sure its fun. Just not as fun as turbo.
art
Old May 11, 2002 | 11:12 PM
csufweed's Avatar
VERY NICE! Its at 6psi. Yes the numbers are quite strong. Most JRSC'd GSR's get 200whp. That can almost pass for a JRSC'd Prelude. I like my s/c... fun enough since I dont live in a no smog environment.
Old May 11, 2002 | 11:13 PM
sgT's Avatar
sgT
Default Re: JRSC GSR Dyno Graph (Arturbo)
this particular car has more ***** than most of the b20vtec NA setups i have seen
also, just like all the other JRSC cars i have dynod, it needs more rpm, it can make
even more power.
Old May 11, 2002 | 11:15 PM
SEFIxCivic's Avatar
why is it that often times a car running all motor will make a little less power than the JRSC but will be much quicker in the 1/4? seems like the mph is higher on the all motor also?
Old May 11, 2002 | 11:17 PM
sgT's Avatar
sgT
Default Re: JRSC GSR Dyno Graph (SEFI8LOxCivic)
good question, i havent seen too many JRSC running but i would think its related
to the phenomenon of NA cars running faster than turbo cars making more power.
Old May 11, 2002 | 11:23 PM
SEFIxCivic's Avatar
that's true too. i've never driven a fast all motor car before... but people who i know that have them tell me that compared to turbo it feels slow, but when you go collect your timeslip it's actually pretty quick. the opposite is true for a turbo car... in a moderately fast turbo car... you feel like your going really quick, but when your collect your slip its not what you expect.
Old May 11, 2002 | 11:26 PM
csufweed's Avatar
even more power.
DEFINITELY!! With just a butt dyno, I feel it pulling harder and harder towards redline only to have to shift when it was starting to get REAL fun.
[Modified by csufweed, 8:27 AM 5/12/2002]
Old May 11, 2002 | 11:31 PM
csufweed's Avatar
i think its more drivers fault, than the cars fault. Extra torque does cause problems launching without the correct wheel set-up. with my previous set-up using low profile Z-rated yokohama's on 16" rims, I couldn't go more than half throttle or else I'd get major wheel spin. Plus, extra weight & heat may play a factor, too...
Old May 11, 2002 | 11:38 PM
SEFIxCivic's Avatar
Default Re: JRSC GSR Dyno Graph (csufweed)
but on slicks the 60fts. are really similar. which also makes me wonder... how come we never see any wheelie bars on a all motor setup? not worth the extra weight? has anyone tried?
Old May 11, 2002 | 11:48 PM
IM ALL BOB's Avatar
well I believe the purpose of the wheelie bars was to help the Turbo FWD guys get traction by not allowing the front to lift when they launch which would only cause the rear to squat for a second.. thus they lose tracion.. by the use of wheelie bars they are able to keep maximum weight on the front tires to insure proper launch and wheelspin..(dude it's like really late did I make sense) heeh and basically ALL motor setups are not hindered by high torque output so wheelspin is less of a issue..as you can easily see a lot of 10sec hondas went to 9's pretty quickly with the use of the wheelie bars *smacks himself* stop rambling dammit =P
Old May 12, 2002 | 12:51 AM
Etylorcen's Avatar
Default Re: JRSC GSR Dyno Graph (pandafreak)
Beautiful torque curve....almost 225hp and 150ish ft*lbs. Torque from off the line. I like it.
Old May 12, 2002 | 12:52 AM
Rory Breaker's Avatar
Hopefully you can recreate those #'s for me as soon as I have the loot stashed for the Hondata! Excellent man
Old May 12, 2002 | 02:18 AM
DIRep972's Avatar
Smarter than you
Default Re: JRSC GSR Dyno Graph (SuperDragII!!!)
nice baby torque actually if it was VW like, it would peak about 2800 and fall off horribly towards redline.
Old May 12, 2002 | 03:13 AM
DIRep972's Avatar
Smarter than you
Default Re: JRSC GSR Dyno Graph (DIRep972)
on another note, that is some very impressive hp for a JRSC.
Old May 12, 2002 | 05:57 AM
Boo Boo'n's Avatar
JRSC =
i've not once seen good results from them.. well maybe twice..
Turbo = The way to go in a honda
Old May 12, 2002 | 06:43 AM
2kbill's Avatar
Thanks to Steve for your hard work & tuning expertise. The ride home from Richmond to Baltimore went quick. I kept cycling from vacuum thru boost, enjoying the smooth transition JUST LIKE BUTTA!!
This morning I went for a quick drive to see how it acted when cold. It hasn't run this well when cold since before the FMU.
sgT & Hondata
Old May 12, 2002 | 07:45 AM
Default Re: JRSC GSR Dyno Graph (2kbill)
Bill that was yours? Congratulations! Big jump from the #'s you were putting out before.
Is that with the Kami 2.5/Carsound? Still with ITR exhaust as well?
Old May 12, 2002 | 07:59 AM
SiRkid's Avatar
Default Re: JRSC GSR Dyno Graph (newgsrdriver)
nice dyno!
jrsc'd cars (gsr, si) are most definately fun to drive!!!! but not enough power for me plus the fact that around where i live every one and there grandma drives a supercharger honda (jrsc) i CANT count on both hands howmany people i know personallly that have one.
[Modified by SiRkid, 5:00 PM 5/12/2002]
Old May 12, 2002 | 09:30 AM
speedy108's Avatar
Default Re: JRSC GSR Dyno Graph (SiRkid)
What is your setup on the car to get that kind of HP on just 6psi?
Old May 12, 2002 | 11:13 AM
FAST94GSR's Avatar
New User
Default Re: JRSC GSR Dyno Graph (speedy108)
That would be perfect for roadracing. Look at the fat torque curve he has.
Old May 12, 2002 | 12:40 PM
sgT's Avatar
sgT
Default Re: JRSC GSR Dyno Graph (FAST94GSR)
IF you could fine a way to keep the charger from overheating.
