JB Weld+ Freeze plug
Old Oct 16, 2005 | 12:28 PM
andysila's Avatar
Default JB Weld+ Freeze plug
i dont know whos picture this is, but i need to use to to ask this question.
1/3 of the hole (where the freeze plug goes) broke off during the hammering process, could JB Weld fix it up?
this is for a sfwd, gsr block.
Old Oct 16, 2005 | 12:45 PM
andysila's Avatar
will it hold..
Old Oct 16, 2005 | 12:58 PM
adictionbass's Avatar
Default Re: (andysila)
probably but maybe not
Old Oct 16, 2005 | 01:20 PM
Boosted2K's Avatar
Default Re: JB Weld+ Freeze plug (andysila)
I have seen this hole completely sealed with something, actually looked like it was JB Weld. This was on a Pro car. It could have been something else though, if its that important, let me know and I'll call the shop and ask.
Old Oct 16, 2005 | 01:39 PM
BodyKits NW's Avatar
Default Re: JB Weld+ Freeze plug (Boosted2K)
Yah JB weld will fix that right up. Just make sure you prep the area well and let the JB weld setup over 24 hours.
Old Oct 16, 2005 | 03:24 PM
DRAGLS's Avatar
Default Re: JB Weld+ Freeze plug (BodyKits NW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andysila &raquo;</TD></TR><TR><TD CLASS="quote">
this is for a sfwd, gsr block. </TD></TR></TABLE>
that's my block going in my beater
And to answer your question yes JB weld will work
Old Oct 16, 2005 | 04:34 PM
White Smoke's Avatar
i my honda
Global Mod
Ya, JB weld should hold. Defentally prep it and let it dry.
Old Oct 16, 2005 | 04:49 PM
BigMoose's Avatar
Surface prep is your key to success. No oil anywhere the epoxy is expected to bond. Roughen up the surface with an abrasive, clean with acetone, lots of acetone.
And I go against the H-T norm. I think JB Weld is for home repairs. Real men use Devcon. Give this stuff a try, http://www.devcon.com/devconfa...id=34 you will never go back to JB Weld.
BTW you can buy it at WW Grainger http://www.grainger.com McMaster Carr at http://www.mcmaster.com and most large industrial bearing supply companies have it. It's not cheap, but it works when you are jammed against the wall. I have used it in industrial situations, and my Dad did before me... Now thats a recommendation!
Good luck.
Old Oct 16, 2005 | 05:10 PM
i my honda
Global Mod
Default Re: JB Weld+ Freeze plug (BigMoose)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigMoose &raquo;</TD></TR><TR><TD CLASS="quote">And I go against the H-T norm. I think JB Weld is for home repairs. Real men use Devcon. Give this stuff a try, http://www.devcon.com/devconfa...id=34 you will never go back to JB Weld. </TD></TR></TABLE>
Its so expensive! Iv used it before.
Defentally top notch stuff
But, JB weld will hold fine and you can get it at Walmart
Prep is KEY!
Old Oct 16, 2005 | 09:32 PM
andysila's Avatar
Default Re: JB Weld+ Freeze plug (White Smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAGLS &raquo;</TD></TR><TR><TD CLASS="quote">that's my block going in my beater
And to answer your question yes JB weld will work</TD></TR></TABLE>
haha im sorry for not asking if i can use it, but thanks anyways.
okay cool, thanks a lot guys.
Old Oct 16, 2005 | 10:09 PM
ScottEK's Avatar
What block and what number freeze plug were you using? I did mine yesterday with a Dorman 555-104 and it hammered in perfectly in about 3 hits with a rubber hammer.
Old Oct 17, 2005 | 02:04 AM
choiboiracing's Avatar
Default Re: JB Weld+ Freeze plug (ScottEK)
nice question andy
Old Oct 17, 2005 | 05:06 AM
ramrod's Avatar
Default Re: JB Weld+ Freeze plug (choiboiracing)
JB Weld works miracles
Old Oct 17, 2005 | 05:38 AM
whoneedzvtec's Avatar
Default Re: JB Weld+ Freeze plug (large farva)
no! dont use jb weld! i have tried it on one of my freeze plugs and a couple of days later it was burned off. well 90% of it was. use magnum steel. every automotive store should have it. magum steel is the ****, trust me i had the same problem as u.
Old Oct 17, 2005 | 06:32 AM
andysila's Avatar
Default Re: JB Weld+ Freeze plug (dc2ls-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by choiboiracing &raquo;</TD></TR><TR><TD CLASS="quote">nice question andy </TD></TR></TABLE>
I think the JB weld will do the job gary
Old Oct 17, 2005 | 08:44 AM
nfn15037's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScottEK &raquo;</TD></TR><TR><TD CLASS="quote">What block and what number freeze plug were you using? I did mine yesterday with a Dorman 555-104 and it hammered in perfectly in about 3 hits with a rubber hammer.</TD></TR></TABLE>
Obviously it was too damn big!
Old Oct 17, 2005 | 09:45 AM
Toda Party's Avatar
Default Re: JB Weld+ Freeze plug (nfn15037)
I am using a jb-welded freeze plug in the same exact location, no issues. no oil leaks. thing doesnt move at all. i forget what size, i think its 34.3mm (hole size) so i think i used a 34mm plug... coudda been 33
Old Oct 17, 2005 | 10:07 AM
andysila's Avatar
cool, so im pretty sure the jb weld will hold up.
thanks for all your guys' help.
Old Oct 17, 2005 | 11:19 AM
Pay2play killa's Avatar
JB Weld rocks; its holding in my endyn block posting studs;
6k mi 1000+ of which were/are boosted hard; no leaks
fbp-em1
Honda S2000
Mar 11, 2008 06:22 AM
92civicx
Sep 18, 2007 04:44 PM
sneakypete
Mar 8, 2007 04:50 PM
Joey.
Apr 20, 2006 03:41 PM
ICeDoUt
Nov 12, 2004 08:57 PM
