itr lsd with boost?
Old Jun 7, 2002 | 05:31 PM
fast[R]'s Avatar
Default itr lsd with boost?
how much hp can this dif take, enyone?
Old Jun 8, 2002 | 09:05 AM
SiRkid's Avatar
Default Re: itr lsd with boost? (fast[R])
not much
Old Jun 8, 2002 | 09:11 AM
jinxproof99's Avatar
New User
at least 300 to the wheels.
Old Jun 8, 2002 | 09:12 AM
Dee's Avatar
Dee
Default Re: itr lsd with boost? (jinxproof99)
after 300whp they become rolling bombs!
Old Jun 9, 2002 | 06:27 PM
fast[R]'s Avatar
Default Re: itr lsd with boost? (Dee)
What do you mean bomb? how does the itr dif work is it a cluch or what?
Old Jun 10, 2002 | 03:21 PM
fast[R]'s Avatar
Old Jun 10, 2002 | 07:07 PM
turbotypeR@SPEC's Avatar
25 Year Member
no problem here yet. although axles are a big problem
Old Jun 10, 2002 | 07:45 PM
dbman96's Avatar
New User
Default Re: itr lsd with boost? (turbotypeR)
Probably depends a LOT on how you drive it... I have a street driven turbo GSR with the ITR lsd and it's never been a problem in about 20,000 miles at around 240-250 hp at the wheels, but I imagine if I took it to the track and did clutch drop starts at 8000 RPM it would grenade pretty quick.
ITR lsd is a helical gear-type LSD like the Quaife but not as heavy-duty.
Old Jun 11, 2002 | 07:17 AM
4dGSR at work's Avatar
Default Re: itr lsd with boost? (dbman96)
if you get bad wheel hop its bye bye lsd
Old Jun 11, 2002 | 03:55 PM
fast[R]'s Avatar
Default Re: itr lsd with boost? (4dGSR at work)
thanks for the info can I fit a weldid dif from an ls or gsr will it fit?
Old Jun 11, 2002 | 04:14 PM
dbman96's Avatar
New User
A WELDED diff? Do you plan on driving on the street at all?
Old Jun 11, 2002 | 04:24 PM
fast[R]'s Avatar
Yes only in the sumer, I have a couple of friends runing welded diffs and no power steering, not too bad going straight, a lil hard turning but no problems
Old Jun 11, 2002 | 07:00 PM
SOUNDEFFECTS's Avatar
I'll buy it if you decide to get rid of it....heck I will even trade you for a welded Diff in stock!
boosted91crx
Transmission & Drivetrain
10
Jun 29, 2009 07:09 AM
lsvtec hf
Feb 24, 2009 02:06 PM
JBk24crx
May 20, 2003 02:04 PM
GQ 05YellowEVO8
Feb 7, 2002 07:59 AM
meanteg
Dec 9, 2001 02:41 PM
