ITR flywheel on LS?
Old Feb 20, 2002 | 06:47 PM
InfamousRS's Avatar
Default ITR flywheel on LS?
Can you put a ITR flywheel on a b18b? How much do they weigh, how much does the stock b18b flywheel weigh? Would it be a good choice for the ClutchNet stage 2? About how much would a used ITR flywheel cost?
Old Feb 20, 2002 | 06:49 PM
dustin's Avatar
Default Re: ITR flywheel on LS? (BLK94RS)
Yes, like 14-15lbs, like 18lbs, yes, under $100
Old Feb 20, 2002 | 06:52 PM
InfamousRS's Avatar
Default Re: ITR flywheel on LS? (dustin)
The reason I asked is because I though you said a while back that you had problems getting it to fit on your ls??? Maybe I remember wrong. Anyways, if I did that would I need to get the flywheel resurfaced?
Old Feb 20, 2002 | 07:12 PM
dustin's Avatar
No it fits fine... I had trouble fitting the Prelude flywheel that some tool sent me on my LS. Of course, he said it was an ITR flywheel =P
Resurfacing the flywheel is always a good idea, but you can get away with not doing it if the surface is smooth and there is little wear..
Dustin
Old Feb 20, 2002 | 08:03 PM
B20LS-T's Avatar
New User
I think the ITR flywheel weighs 12 pounds. I will find out friday becuase Im getting a quote on one from my friend that works at acura. The stock flywheel weighs 18lbs.
Old Feb 20, 2002 | 08:18 PM
InfamousRS's Avatar
Dustin
Yeah, thats what I remember.
I figured there is no way Im going to beable to get the turbo setup I want anytime soon, so Im figuring out ways to still be effective but spend less money.
Im goint to go with the DRAG 3 kit @ 9 psi, 310cc injectors, Clutchnet stage 2, ITR flywheel, and my current 5 Zigen exhuast. I THINK
Then I can upgrade everything slowly as I get more money.
Old Feb 20, 2002 | 08:21 PM
BlowOff's Avatar
New User
I've been running a Type R flywheel on my LS for a year with no problems. I got one brand new from A&H motorsports for a great price.
Old Feb 21, 2002 | 10:15 AM
dustin's Avatar
Default Re: ITR flywheel on LS? (Turismo79)
it's not 12lbs, I have one and it was shipped to me. UPS was nice enough to label the package with the weight =P
Dustin
Old Feb 21, 2002 | 10:33 AM
VaporTrail's Avatar
New User
personally, I would just have your stock flywheel machined down to around 12-13lbs. Works great for me
Old Feb 21, 2002 | 07:21 PM
InfamousRS's Avatar
Default Re: ITR flywheel on LS? (VaporTrail)
Is that all the ITR flywheel is, just a machined down version of a normal Teg flywheel?
Those with the ITR flywheel, can you tell a big difference in how fast the motor revs or turbo spools up over the stock fly wheel?
o0oz
Jan 16, 2007 12:07 PM
jdmekcivic2eg
Mid-Atlantic (Sales)
May 26, 2006 12:40 PM
asianridr
Mar 29, 2002 05:59 PM
