ITR 81 (k20z1 + Boost)
Old May 16, 2009 | 08:26 AM
done's Avatar
Default ITR 81 (k20z1 + Boost)
After a very long time (3 years +)...... the car finally runs..
Setup:
K20z1 Engine
K20z1 Transmission
AFI Turbo Kit
GT35r turbo
Hybrid Racing A/C Kit
Pneumatic Vacuum Kit (from http://www.pneumatickits.com)
Photos:
If you have any questions about the swap, Post them up!!
done's Avatar
Default Re: ITR 81 (k20z1 + Boost)
I purchased my car when I was a junior in high school. (2002)
I took me about 2-3 years to save enough money to buy my 1st turbo kit.
Here is a webpage I made to show the setups I've been through.
My Favorite was my 2nd setup. Dual wastegates, built motor, everything was simple. Made 433whpish.
http://www.pneumatickits.com/hosted/kap/car.html
Old May 16, 2009 | 08:32 AM
SilverEk3dr's Avatar
You coulda had a 700+whp b-series for what you paid for the k
Old May 16, 2009 | 08:43 AM
done's Avatar
can you tell me why anyone would want a 700whp integra for a street car?
Here is a more recent photo.
Old May 16, 2009 | 09:10 AM
96 GSR-T's Avatar
Who knows, my Teg street car should make somewhere between 750-800hp later this year, 4th gear should be fun ....
Sick setup though
Old May 16, 2009 | 09:17 AM
No doubt the car is sick, but I think you just contradicted yourself?
So u swapped a K and turbo'd it for less hp? Im not trying to hate, but Im not sure I follow..
Oh and BTW I would like a 700hp integra. Come to find out 500whp is not enough for me
Old May 16, 2009 | 09:57 AM
done's Avatar
K-series motors have a much better powerband.. It doesnt make less power either. Should make 450whp 14-15psi.
They have alot better technology also.
Old May 16, 2009 | 10:39 AM
marcj's Avatar
I agree with the other guy.. you spent all that money, and will end up dropping a valve or cracking a sleeve way before you'll get EVEN CLOSE to what a B-series would do with that same investment. Oh well, live and learn.
Old May 16, 2009 | 10:49 AM
done's Avatar
Did i mention it took 3 years for the k-series motor to go in?
I wasn't exact motivated anymore. I sold all the b-series stuff to pay the car off. Was planning just a simple all motor kseries setup because I still enjoyed the car. Overtime, opportunities arrived, and I acquired a turbo kit. I wasn't planning going from a full built bseries setup to another stock turbo kseries setup. It just happened that way.
Overall, Im really happy the car moves on its own power. No more pushing it around the garage.
Old May 16, 2009 | 12:46 PM
TheShodan's Avatar
Moderator
very well done. Not many people use the vertical fin intercooler except DSM cats.. Nice to see something a bit different. (At least this is what I gather from the photos posted)
Old May 16, 2009 | 12:56 PM
Kevin's Avatar
Looks very well done.
I don't know why you're getting bagged on for going K on boost. If you can afford it, it's definetly worth it. Sure, a B series can do the job more than adequetly on the street and for less money but the K's have a better powerband and can handle a bit more abuse if set up correctly. Me personally i like the simplicity and cost of a boosted B series but wouldn't turn down the chance to have a similar setup to yours.
Old May 17, 2009 | 07:20 AM
AJxr's Avatar
first itr ive seen with a k, maybe thats what ticks ppl off.
ppl gave me the same feedback when i went from built vitara d16 to stock ls boost... the ls might not hold the same power peak... but its a lot faster because of a better powerband, lag, etc.
car looks good.
Old May 17, 2009 | 08:40 AM
m R g S r's Avatar
Is this jordan?
Old May 17, 2009 | 03:06 PM
ef4dr's Avatar
lol i did the same thing... 2.0L sleeved topmount t67 ditched for a stock block k20a2 with a full-race t3/67 setup...
pump gas vs pump gas same boost the stock k makes more power sooner everywhere
and there are quite a few k's with just pistons and rods in the low to mid 700 range out there running everyday on the st. check k20a.org on that one
nice build
Old May 17, 2009 | 03:17 PM
SD_Lurker's Avatar
HT White Ops
Now he can tell everyone he has a K series.... To each his own.
Old May 17, 2009 | 05:46 PM
92civicx's Avatar
**** it spend ur money on wutever the **** u want, **** everybody tryin to find the reson in this, all u gotta say is cuz i ****in wanted to. u dont gotta explain ****. nice setup
Old May 17, 2009 | 07:12 PM
418whpturboD's Avatar
u did what you want.. i think its badass
Old Aug 4, 2009 | 06:07 PM
done's Avatar
Originally Posted by m R g S r
Is this jordan?
its me, evan. hows that s2k coming?
Originally Posted by coolhandluke
This is your 6th+ turbo/engine setup correct? I say that from the standpoint of setup progression. I am not implying that you blew it up repeatedly.
1st setup:
Stock b18c5
Full Race Manifold (40mm wastegate) with t3/67 turbo
10-14psi (boost creep blew motor)
300-350whp
2nd setup:
Built b18c5
Full Race Manifold (44mm wastegate) with t3/67 turbo
10-14psi
300-350whp
power
3rd setup: MY FAVORITE SETUP!!
Built b18c5
Full Race Manifold (DUAL 44mm wastegates) with t3/67 turbo
12psi low boost, 15psi high, 20psi race gas
350-450whp, 503whp race gas
power
4th Setup:
Built b18c5
Lovefab T4 manifold (44mm wastegate) with t4/67 turbo (ball bearing)
12psi low boost, 15 high
360whp-470whp
power
5th Setup:
Built b18c5
Full Race Top Mount Manifold (44mm wastegate) with t4/67 turbo (ball bearing)
12psi low, 20psi high
370whp-512whp
6th Setup:
Stock K20z1
AFI Sidewinder Manifold (44mm wastegate) with gt35r turbo
10-14psi (doesnt hold boost, creeps)
NO idea on power, still needing good street tune + iat sensor for ivtec to work.
The ITBS and supercharger never ran on the car. The car started with the turbo kit on it. Everything only has 55-60miles on everything. The car has been running for 6 months.
Originally Posted by nashville
i can only imagine the headaches you went thru with that build
The car is a big headache actually. Everything on the car goes wrong. Clutchs, motors, leaks, leaks, leaks. You name it, it has leaked. I have learned alot though over the years. I wouldnt give up any of it. Everything has been good experiences with the car.
Ive done ITR expo in 2004, 20-30 Autocrosses, 1-2 road courses. Owned a internet part company.
I havent done much with the car in about 3-4 years though.
Old Aug 4, 2009 | 07:36 PM
ctr32's Avatar
what the **** do u do for a living??
Old Aug 5, 2009 | 01:23 AM
TurboK's Avatar
K series or nothing,nice setup.
Old Aug 5, 2009 | 04:38 PM
BLB's Avatar
BLB
lookin good sick setup
Old Aug 5, 2009 | 05:22 PM
Teglove2's Avatar
No ****! 5 setups! Not just a turbo swap neither geez I thought I was bad. But mad props for a k turbo black integra....My car doesnt even hold race gas power on the street its really upsetting! That k motor is gotta be a blast and much smoother than the b. Nice ride bro
Old Aug 6, 2009 | 12:58 AM
omiehomie's Avatar
hell yea +2 for a K series dc2R. my problem is that i went with the non boost friendly R version and it still a blast to drive ^_^
its your caR man and YOU do what YOU want not what anyone else on a bandwagon tells you to do.
cant wait for the #'s this mo fo puts out
Old Aug 8, 2009 | 09:17 PM
done's Avatar
Im currrently having boost control issues, but its very "boosty." I get 3-4psi around 3-3.5rpms.
The motor makes power in any gear. Its nuts.
Old Aug 9, 2009 | 04:57 AM
Silva Bullit DC4's Avatar
WOW.
Cats in here are actually hating because you spent YOUR money on a K setup. C'mon guys, its HIS money, if thats what he wants to do, then so be it.
Nice setup man.
