Issues with a bit of compressor surge (greddy type s)
Old Jul 6, 2005 | 07:29 PM
JDM EJ1 95's Avatar
Default Issues with a bit of compressor surge (greddy type s)
heres a problem i have...
when boosting lower levels 1-2 psi and not really getting into the car at all.. just normal acceleration really theres a slight compressor surge and then the bov will hit......
now i really cant tell if its happening at full boost when im driving it hard because the dp is too loud lol...
im only running the spring on my tial which is at 7.2 psi
ive tried to adjust the bov.. its on the softest setting the screw can go without really falling out.....
ive also ran the bottom port on the BOV to the nipple on the TB bc i heard that helps the response of the blowoff valve
nothing helps... i dont really wanna keep driving like this
the blowoffvalve worked fine on the setup when it was on my friends car... but he was boosting at like 11psi.... im sure the greddy should function properly on 7psi....
ahh setup time
1994 b18b
neukin mani
garrett t3 t04e 57 trim .63ar
RC 550s
walbro 255
HONDATA tuned
tial 38mm wastegate
open 3 inch dp
JRC backdoor intercooler
*GREDDY TYPE S!!!!!!!*
Old Jul 6, 2005 | 08:15 PM
beepy's Avatar
Default Re: Issues with a bit of compressor surge (JDM EJ1 95)
The Greddy BOV is available with a "standard" and a "stiff" spring. Maybe you got the stiff one.
Old Jul 6, 2005 | 08:49 PM
bluemax189's Avatar
Default Re: Issues with a bit of compressor surge (beepy)
dont connect the bottom to any line anywhere. that tube is not used for boost or vacuum. its used as like a neutral to balance the pressure inside the BOV. i read this somewhere else, not sure if i said it right, but you get the pic, dont connect the bottom line.
Old Jul 6, 2005 | 09:08 PM
Tchleung's Avatar
Default Re: Issues with a bit of compressor surge (bluemax189)
No the proper way to set it is to connect the lower nipple to a boost source. But leaving ti open works just as good. I like it betetr not connecting as it sounds better lol....
Old Jul 6, 2005 | 11:06 PM
JDM EJ1 95's Avatar
ahhh anyone wanna help me out? ive tried both ways.. on or off doesnt make an *** of a difference
Old Jul 7, 2005 | 04:51 PM
Tchleung's Avatar
Try only if you really want to.. I read from a few guys on here that they had the same problem and they oepned up the BOV to find TWO sprigns inside. one stiff and one soft. they took out the stiff one and elft the soft one in and now it works flawlessly. pobviously they ahd to tighten it some more but it worked for them.
BTW, I'm ahving the same problems as you and I'll be opennig up my BOV when I get my car back from the bodyshop.
Old Jul 7, 2005 | 06:53 PM
JDM EJ1 95's Avatar
i took the stiff one out and it works great now.. hahah thanks
Old Jul 7, 2005 | 07:00 PM
Tchleung's Avatar
haha no problem. I'll be doing it as well. Did you have to adjsut it muchh after taking out the spring?
Old Jul 7, 2005 | 09:52 PM
JDM EJ1 95's Avatar
yea i tightened it down like 5 tunrs
Old Jul 8, 2005 | 04:36 PM
Tchleung's Avatar
Good to know. Now go pass on your new knowledge :D
Old Jul 8, 2005 | 05:56 PM
Dr. D-Series's Avatar
My knock off RFL gives me some compressor surge at 1-2 psi.
The ******* spring inside is huge.
Good thing ive got a 75 dollar turbo.
BDogggUT34
Mar 14, 2009 08:58 PM
b18sihatch
May 16, 2006 11:46 AM
ThePro
Nov 10, 2004 09:36 AM
KC GSR
Dec 30, 2002 07:55 AM
Pengo
Jul 15, 2002 03:54 PM
