Intercooler Piping Beads
What's the best method to bead piping so that connectors are less likely to blow off? I know that it's done with a press, and that some people just put a nice lump of weld around the pipe to achieve the same effect, but how it is actually supposed to be done, and can it be done effectively for cheap?
And yes, I did a search
How important is it that the size (height) of the weld bead be remain consistent all the way around?
I know it's not the most important thing or anything, I just figured I'd ask before going ahead and doing this on my IC piping which I don't want bother re-doing because me bead method sucked
well the welded bead works, but if you want to be the cool kid on the block with the trickest part check these out!
These couplers clip onto aluminum 2.5" piping, and then must be welded, the coupler then goes between them with 2 hose clamps like normal. There are 4 rows of barbs that act to seal your pieces of tubing and keep your pipes from blowing apart, just like a hose barb fitting for a vacuum line!
Another way to do it is to put a little bit of a "lip" on it by taking a long scredriver and using it to flare out the edge of the pipe. This will make it stay in the coupling without falling off.
kinda a ghetto version of the wiggins clamps...pretty cool
You can mod some plyers by welding a bump on one side, and grinding away the other side, then use that to crush a lip in the end of your pipes.
If you made them in some sort of steel material then i would buy 5 or more sets. I dont know of anyone that runs aluminum intercooler piping since its so damn expensive compared to mild steel.
