Intercooler
Old Jul 16, 2012 | 06:29 AM
jap lowrider's Avatar
Default Intercooler
Hey guys
im sitting in a sort of dilema here
my setup at the moment
84mm b16
forged pistons and eagle rods
acl bearing
turbonetics t3 t04e 57trim .48
stock head
63mm boost pipes from the cooler to the intake
from the turbo to the cooler its 50mm
custom built equal runner maifold
400x200x50 universal cooler
power is 182wkw and 256nm (stingiest dyno around)
now i want to turn up the boost and from what i seen most if not all the honda tech guys run big coolers 600x300x76
now some of the local guys here say that would be overkill for what i have.
but i had a buddy with a gsr where he ran a big cooler and made basically 30wkw more then other b18c's with the same setups.same turbo and boost
so will my current 400x200x50 cooler surfice or would i need to change it to 600x300x76? im running 0.8 bar and want to push it to 1.1 to 1.2 bar
Old Jul 16, 2012 | 06:45 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Intercooler
Measure in and out temperatures of the intercooler and this will let you know if it's efficient enough or not. (Under boost obviously.)
Old Jul 16, 2012 | 08:32 AM
wantboost's Avatar
Who is Mr Robot?
^thats the best way...
Old Jul 16, 2012 | 01:29 PM
realwheeldrive's Avatar
look for fin design and core design on cooler as well if you do decide to upgrade.
Old Jul 16, 2012 | 11:25 PM
wantboost's Avatar
Who is Mr Robot?
yea the construction of the intercooler core matters as well. from the sound of it you're simply running a typical ebay intercooler... they are ehhh. I mean they'll work but the arent the best... and they have abnormally high pressure drop. Like 2 psi across the intercooler at 20psi inlet pressure, whereas a well designed intercooler is between .5-1.o psi drop across the intercooler
J . K .
Jul 8, 2010 04:24 AM
Turbo-charged
Aug 30, 2007 05:36 PM
Duck Sauce
Nov 26, 2001 02:43 PM
ken
Sep 28, 2001 06:39 AM
prjctCIVIC
Jun 26, 2001 03:29 PM
