Integra radiator clearence issues
Im getting ready to boost my 96 LS , and well while taking some measurements and checking clearance it appears that the radiator interferes with the wastegate off the ramhorn . Im sure someone else has had this issue , so will a civic radiator work ? Any other suggestions ?
I had a log manifold and was able to use a fluidyne fullsize radiator however it was a internal wastegate. I'm not sure if there is anyone out there with external wastegate and ramhorn manifold that doesn't use a civic half sized radiator. Get yourself a koyo, fluidyne, or PWR. They are all good raidators and all you have to do is cut/reweld your mounts which isn't that big a deal.
a civic rad will work, but you shoudl consider an aftermarket one, fluidyne or koyo are most likley the best choices. you will have to cut and reweld the bottom mount but that's not that big a deal. less than an hr of time (one you have the new radiarot your going to use)
NyQuiL
Aug 27, 2003 11:08 AM
