Intakes?
Old Aug 26, 2002 | 07:56 PM
Stumpy's Avatar
Default Intakes?
This is just a question that's been bugging me for awhile, so i figured i should ask. I did a search and couldn't find anything, maybe i'm just stupid.
Anyhow, if you're running a turbo setup, do you still use a normal intake? IE: AEM CAI, or stock intake?
Thanks
edit: Well, when i searched I did find lots of things on "intake manifold" I'm not really sure if the "manifold" part constitutes something different than a standard intake.
[Modified by Stumpy, 12:03 AM 8/27/2002]
Old Aug 26, 2002 | 08:47 PM
inspyral's Avatar
Default Re: Intakes? (Stumpy)
Charge piping replaces your intake. Air would go in thru the turbo's inlet instead of thru an intake like it normally does when you're N/A. You can put an "intake" on the turbo inlet, but it's more of a short pipe or bend with a filter on it, kinda like a shorter intake but on your inlet instead connected to the throttle body.
ptown909
Dec 3, 2008 11:02 PM
logg_frogg
20
Sep 17, 2008 12:01 PM
anton_
Mar 12, 2007 10:56 AM
natoriousbao
Aug 4, 2005 09:57 PM
