Instant CEL???
Old Jun 11, 2005 | 01:41 PM
EGP's Avatar
EGP
Default Instant CEL???
Hey guys, have a question you can hopefully answer.
I have a 99 Si with a ODB2b to OBD1 conversion harness and a chipped p28.
I'm getting an instant CEL, it comes on when I turn the key to ignition without even starting the motor.
I've tried jumping the ECU to pull codes but it doesn't do it, the CEL just stays constant.
When started the car idles and runs fine, no limp mode.
My plugs are new and I'm in the process of changing my O2 sensor, had a few limp mode drives before I got the p28, and it has to be bad by now. But I don't if that will take care of it.
What else could it be, maybe another sensor I need to unplug or rewire???
Appreciate any help thanks.
Old Jun 12, 2005 | 01:43 PM
EGP's Avatar
EGP
Default Re: Instant CEL??? (EGP)
It still comes up even when I reset the ECU by pulling a fuse......
Old Jun 12, 2005 | 01:45 PM
alpha's Avatar
My guess it's either the conversion harness or the ECU. If possible try another conversion harness (a friend or someone local) and ECU.
Old Jun 12, 2005 | 02:21 PM
EGP's Avatar
EGP
Default Re: Instant CEL??? (0x64)
Yeah I'll try that, I have a 95 prelude ECU, it's not VTEC, but it may show me if the CEL comes on with it or not. Thanks.
Old Jun 12, 2005 | 02:58 PM
alpha's Avatar
My reply is from experience. I have had cars throw a solid many times. 99% of the time it ends up being the wiring or ECU.
Old Jun 20, 2005 | 06:26 PM
EGP's Avatar
EGP
Thanks man, it was the ECU, I just got another one from phearable and it works perfect.
Old Jun 20, 2005 | 06:35 PM
alpha's Avatar
It's no problem. I had no doubt in my mind that would be it. You purchased from a good guy as well.
ef yu
Jan 16, 2012 08:53 AM
rasta420
Apr 6, 2007 08:12 AM
4potnick
12
Aug 21, 2005 01:59 PM
