installing the Victor X
Old May 3, 2004 | 09:56 AM
4-banging's Avatar
Default installing the Victor X
I will be installing the Edelbrock Victor X on my 00 Si this weekend...is it a pretty straight forward install? Will I need any misc. items to complete the install?
thanks in advance...
Old May 3, 2004 | 10:13 AM
FredoSP's Avatar
Default Re: installing the Victor X (4-banging)
mine was easy, make sure you have an intake manifold gasket - that's all I can think of at this moment
Old May 3, 2004 | 10:26 AM
4-banging's Avatar
Default Re: installing the Victor X (FredoSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">mine was easy, make sure you have an intake manifold gasket - that's all I can think of at this moment</TD></TR></TABLE>
is it safe to re-use the OEM one?
Old May 3, 2004 | 10:36 AM
dohcnotec's Avatar
safe but not smart
Old May 3, 2004 | 10:39 AM
4-banging's Avatar
Default Re: installing the Victor X (dohcnotec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcnotec &raquo;</TD></TR><TR><TD CLASS="quote">safe but not smart</TD></TR></TABLE>
sooo, one new intake mani gasket on the order list...
anything else guys?
thanks again
Old May 3, 2004 | 11:55 AM
bluebullet's Avatar
extra vacuum hoses, you're gonna have to re-route almost all of them, also injectors are a pita, you have to re-use bolts from the tb and the fuel rail mount, and you need to make your own hex driver for the end nut to tighten that sucker. I just took it to home depot and got a big nut/bolt and used that to tighten it. If I had to do it over....I wouldn't.
Old May 3, 2004 | 12:03 PM
TRE_'s Avatar
Default Re: installing the Victor X (bluebullet)
might wanna replace the throttle body gasket as well.
Old May 3, 2004 | 12:11 PM
4-banging's Avatar
Default Re: installing the Victor X (THE_HX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluebullet &raquo;</TD></TR><TR><TD CLASS="quote">extra vacuum hoses, you're gonna have to re-route almost all of them, also injectors are a pita, you have to re-use bolts from the tb and the fuel rail mount, and you need to make your own hex driver for the end nut to tighten that sucker. I just took it to home depot and got a big nut/bolt and used that to tighten it. If I had to do it over....I wouldn't.</TD></TR></TABLE>
hoses are taken care of, new mani already tapped for vacuum lines...are you saying for the fuel rail that I'll need the hex driver? what kinda problems will I run into with the injectors.
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THE_HX &raquo;</TD></TR><TR><TD CLASS="quote">might wanna replace the throttle body gasket as well. </TD></TR></TABLE>
it came with a new gasket
Old May 3, 2004 | 12:21 PM
MysteryWagon's Avatar
steps as followed with the manifold
-make sure and clean the head real good of any deposit from old manifold gasket especially around areas envolving coolant
-the hex part is for the large nut in the side of the plenium- make something that will work to tighten it.
-be careful with injectors don't mess up the O-rings
-clean the screen to the IACV cause you will most likely chance throwing a code
-GET a HONDATA intake manifold gasket just a thought
Old May 3, 2004 | 12:45 PM
4-banging's Avatar
Default Re: installing the Victor X (MysteryWagon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MysteryWagon &raquo;</TD></TR><TR><TD CLASS="quote">steps as followed with the manifold
1) check
2) I'll have to check that one, I can't remember off hand what that looks like...I do remember the rear of the plenum having a huge allen fitting nut.
3) check
4) check
5) stuck to OEM
thanks
Old May 3, 2004 | 01:23 PM
bluebullet's Avatar
get a big *** nut and bolt that fits the plenum nut, thread them together completely, then you can use it and a wrench to tighten it. It won't completely seat.
Oh, another thing. If you are using the stock 99-00 si IAT mounted in the piping before the throttle body....you're gonna need a plate to cover the one on the backside of victorx manifold. Mine didn't come with one.
Old May 3, 2004 | 01:32 PM
4-banging's Avatar
Oh, another thing. If you are using the stock 99-00 si IAT mounted in the piping before the throttle body....you're gonna need a plate to cover the one on the backside of victorx manifold. Mine didn't come with one.</TD></TR></TABLE>
I'll have to check that one too...can't get a mental picture of that....Monday and its almost time to go home
94lspower
May 9, 2007 02:53 AM
Seedc2
Apr 1, 2005 09:51 PM
r0cket247
36
May 26, 2004 10:16 AM
EdLeake
17
Feb 23, 2004 09:08 AM
ShaDoWbOi
Jun 16, 2003 06:51 PM
