installing b16 oil pan
Old Mar 25, 2004 | 11:23 AM
Wo-Nelly's Avatar
Default installing b16 oil pan
Whats the proper procedure? I replaced a oil pump and everything is good now but there's still a bit of oil leaking from the pan. I put some on the corners between the gasket and the block nothing between the pan and gasket though. Am I even supposed to use hondabond? If so where exactly? Also whats the torque specs on the oil pan bolts/nuts? I'm scared of breaking them since they're so tiny. I put about 12lbs/ft on them
Old Mar 25, 2004 | 11:26 AM
VaporTrail's Avatar
New User
Default Re: installing b16 oil pan (Wo-Nelly)
i usually coat the entire thing in permatex ultra grey (hondabond) with a light film. Your torque spec is correct
Old Mar 25, 2004 | 11:34 AM
G
sh!t happens.
Default Re: installing b16 oil pan (VaporTrail)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VaporTrail &raquo;</TD></TR><TR><TD CLASS="quote">i usually coat the entire thing in permatex ultra grey (hondabond) with a light film. Your torque spec is correct</TD></TR></TABLE>
Old Mar 25, 2004 | 12:10 PM
dfoxengr's Avatar
Default Re: installing b16 oil pan (G"UNIT)
any sort of ATV sealant will work. high temp is good
Old Mar 25, 2004 | 12:14 PM
FredoSP's Avatar
yuppp H-Bond it up
EK9JSPEC
Apr 20, 2012 01:06 AM
san_luis
Mar 22, 2010 10:09 AM
Rhood
Feb 7, 2007 05:30 PM
y2ks2k
Oct 22, 2003 05:25 AM
