Injectors on zc
Old Jun 7, 2007 | 03:08 PM
teamidscoupe's Avatar
Default Injectors on zc
are there any othere parts that I need when installing DSM injectors on a 92-95 DOHC ZC in an EK
Old Jun 8, 2007 | 01:05 AM
90sedan's Avatar
Default Re: Injectors on zc (teamidscoupe)
They won't fit perfectly into the stock o-ring seats.
You basically have two options:
- dremel out the stock o-rings on the intake mainfold to fit the larger injectors better, and then place fuel rail on top and screw them into place.
- buy the o-ring seats from an eclipse (heard they aren't cheap..have not looked into it though)
I went the first route, while i didnt have a perfect sized dremel bit, i was able to bore them out just enough to fit the tips in snug so that i could screw the fuel rail down on top to clamp them down.
Old Jun 8, 2007 | 02:28 AM
crxnj's Avatar
also, if they're peak and hold, you'll need to get a resistor box.
Old Jun 9, 2007 | 11:21 PM
OK maybe a better question is: what injectors require the least hastle and perform best?
and what do i need to install them?
jining
Oct 8, 2009 01:53 PM
bchap
Engine Management and Tuning
Sep 25, 2009 07:20 AM
efprojectboost
Dec 30, 2007 10:43 AM
EFwithS2000taillights
Oct 11, 2005 06:57 AM
Morbspeed
Jan 13, 2004 05:51 PM
