injectors maxing out ???
Old Jan 30, 2011 | 06:43 AM
bnmm's Avatar
Default injectors maxing out ???
stock z6 8 lbs...rc 440 injectors max out at full load 100% duty cycle 255 fuel pump and 50 psi fuel pressure...from what i read maybee filter bad or pressure fallin off....but what would cause that, i heard about some ppl tuning and take the vaccumm off for regulator whats the purpose of this?
and is s300 if you change base timing to match distributor.. it should change the whole map correct?
Old Jan 30, 2011 | 07:13 AM
SovXietday's Avatar
Default Re: injectors maxing out ???
8lbs on what turbo?
Also, are you just seeing this because it says 100% on Hondata? Did you scale the injectors in the software? If you add more fuel does the car richen up? Understand that the software really has no idea what the duty cycle is on the injectors, it is only finding it mathematically and if you didn't scale for the new injectors it still thinks you're running stockers.
Old Jan 30, 2011 | 07:27 AM
bnmm's Avatar
thats what i was thinkin i changed it from 240 to 440 in fuel trim. and did the fuel trim calc with before and after pressure and injector is there somewher else u have to do it? its an ebay "50 trim" thanks
Old Jan 30, 2011 | 08:01 AM
Spawne32's Avatar
this sounds pretty accurate, 550cc is usually the place to start for turbo car's
Old Jan 30, 2011 | 08:08 AM
bnmm's Avatar
its a stock single cam shouldnt make anymore than 220 hp those injectors should def be supplying more than enough
Old Jan 30, 2011 | 08:10 AM
Spawne32's Avatar
injectors arent rated by hp, it all depends on the turbo he's using and how much cfm it flows
Old Jan 30, 2011 | 06:24 PM
Turbo-LS's Avatar
Injectors are rated by fuel flow which mathmaticaly can be converted to a given hp reating proviing you know BSFC (brake specific fuel consumption) of the engine. The turbo size has nothign to do with how much hp can be made with a certain injector. 440cc injectors should be able to handle in the 300whp range so if the OP is at 220 then its mathmaticaly imposible to be maxing out those injectors unless there is a fuel starvation and the milliseconds ahev to be drasitcally increased as boost pressure rate rises.
My guess is there not scaled properly in the software therefore injector dead time is probably not properly setup as well
Old Jan 30, 2011 | 06:32 PM
racebum's Avatar
huh? injectors are rated by cc or lb/hr it's all the same. 440cc injectors typically max out around 300 crank hp at 50psi
you can use the calculator here to determine what size you need based on hp output
http://www.fuelinjectorconnection.co...widercalc.html
to make 300hp at an 80% duty cycle you need about 590cc's or the 650cc precisions would be a good inexpensive fit
in the op's case if he's making 220whp 440s are more than enough, something else is up
this is rolling with a BSFC of .6 which would be probably be close
Old Feb 3, 2011 | 08:44 PM
SovXietday's Avatar
Ok, bnmm, if you add more fuel does the mixture still get richer or no? Scaling doesn't always work the way it should, the number you should be focusing on is the one the wideband is putting out.
Old Feb 5, 2011 | 04:40 AM
tony1's Avatar
Originally Posted by SovXietday
8lbs on what turbo?
Injector duty cycle is a very simple calculation. Its injector pulsewidth divided by cycle time at a given rpm. Has nothing to do with scaling in the software. The logged duty cycle in Hondata should be correct.
Old Feb 5, 2011 | 08:42 PM
SovXietday's Avatar
^ I stand corrected, thanks for in the info Tony!
Old Feb 8, 2011 | 05:54 PM
bnmm's Avatar
well i put a different filter and pump from my old car that i know worked in it but i havent got the chance to plug it into laptop yet and give it a try once i seen 100% duty cycle i wasnt trying to add more it scared me lol
Steeve_Civic
Jan 13, 2013 10:51 AM
85
Honda Motorcycles
Feb 13, 2007 08:30 AM
JDM turbo DC
Mar 24, 2006 05:44 PM
ATS*Mark
Aug 7, 2004 10:12 AM
