which injectors for a drag 3?
Old Feb 6, 2002 | 12:24 AM
Acura_I-RS's Avatar
Default which injectors for a drag 3?
ok, i have a 94 integra RS, stock motor, im gunna be getting the drag gen3 turbo kit very soon, most likely from ben, and i am just wondering which injectors would be my best bet to get?? i have been told the rc 440's, but is that too much?? or is there any other brands that are descent and not so spendy??? thanks!!!!
Old Feb 6, 2002 | 12:31 AM
austrian type-R's Avatar
Default Re: which injectors for a drag 3? (Acura_I-RS)
The 440cc are only working when you get a standalone ECU to control the injectors.
It depends how high you will boost. 6-7 psi the stock ones are okay but 310cc would be better. The 310cc are good up to about 10psi I guess. Anything bigger than 310 and your stock ECU can not handle those. You will flood the engine with fuel on idle and partial throttle.
HaTa
Feb 5, 2006 12:17 PM
TurboSI24
Oct 11, 2005 03:54 PM
slwazgsr
Sep 26, 2002 05:49 PM
jamal-188
Oct 10, 2001 12:03 PM
GSRrR
Oct 3, 2001 03:18 PM
