which injectors??
Old Oct 7, 2004 | 06:51 PM
turboH22Aakkord's Avatar
Default which injectors??
hi, i'm gona go uberdata on my h22a .... i'm only gona be runing like 6-7 lbs right now untill i do the rebuild. my question is, what it be possible to get like 750 rc injectors to tune down for that low of boost? i just dont want to have to buy 550's and then buy the bigger injectors l8ter on after i rebuild and turn the boost up.
(oh, and i have this jdm h22a in my 92 accord, if i run staturated injectors or high impedance i should be fine without a resistor box right? ) thanks a ton!!
Old Oct 7, 2004 | 07:07 PM
XxRoCkMaNxNEOxX's Avatar
Default Re: which injectors?? (turboH22Aakkord)
how much hp do u want to hit?
Old Oct 7, 2004 | 08:06 PM
CivicGSR225's Avatar
you will be fine as long as your wiring setup with the motor right now isnt wired up with a resistor box, I would buy used injectors cheap for now, then buy the 750s later down the road. I have 460cc saturated injectors for sale if your interested pm me.
Old Oct 7, 2004 | 08:14 PM
JDM.Accord's Avatar
Default Re: (CivicGSR225)
I got 750's in my 97 Accord with my fully built turbo H22. Instead of buying injectors twice just go with the larger ones
sevenj
May 21, 2008 04:50 PM
b16a4
Jun 12, 2007 04:33 PM
Schister66
Apr 26, 2006 08:36 AM
mprelude
Nov 27, 2004 03:25 PM
93B17A
Mar 11, 2002 12:29 PM
