InjectorDynamics.com Bosch 1000cc
Old Nov 22, 2008 | 10:42 AM
  #26
tony1's Avatar
Originally Posted by rickoner
sorry if this is a dumb question, but are these able to support more power than say an rc 1000cc? is so what do you think they would max out at.
These injectors are reliable up to 100psi base fuel pressure. So, assuming your electrical system is up to par (can't drop below 10v during cranking or the injectors won't open at that fuel pressure) and your fuel pumps can provide that pressure (bosch 044's are great at high pressure), then they will be good for a lot of hp. At 100psi base pressure they flow about 1525cc/min. With the right setup, these will make 750whp easily and drive like a car with 440's!!!
Old Nov 22, 2008 | 11:49 AM
  #27
tony413's Avatar
looks like i need to scrap my bosch 1600's and FJO box
Old Nov 22, 2008 | 12:50 PM
  #28
twkdCD595's Avatar
Definately tempting to change to these from my 1000/cc precisions I currently run hearing their benefits.
I always considered myself lucky that the accord came with a resistor box from the factory so I did not have to mess with adding one or being limited on injector size without. Now enter these to the market... makes me think about taking out my resistor box...
Old Nov 22, 2008 | 01:51 PM
  #29
slooogsr's Avatar
Maybe Santa will bring me a set for Christmas......
A trip to see Chris @ Xenocron for more boost and a tune in the spring maybe in the works....
Old Nov 22, 2008 | 05:43 PM
  #30
MikeySpec's Avatar
I just installed and tuned my first set of these this weekend. Unbelievable, i never thought 1000cc's can run like that. Much thanks to Xenocron for setting me up with them.
Old Nov 22, 2008 | 06:41 PM
  #31
legomytego's Avatar
are you shitting me i just put in a order for rc1000s today thease are only alittle more if they run like you say they do i will cancel my order
Old Nov 23, 2008 | 09:00 AM
  #32
alpha's Avatar
I wouldn't have made this post if they were not as good as Tony said they were. I'm getting ready to place an order for three more sets here soon
Old Nov 24, 2008 | 11:33 AM
  #33
xenocron's Avatar
Told you that you'd love them
I switched from RC550 Highs in my own personal car to these...and they work better. Better idle (no pop pop) better part throttle (I can lean cruise much easier) and same feel when at WOT.
Old Nov 24, 2008 | 11:37 AM
  #34
98vtec's Avatar
moderator emeritus
the design of them are much like the RDX injectors. I absolutely love them. My 12.2:1 motor can run 16.8 - 17:1 without a hiccup in high-mid vacuum.
Old Nov 24, 2008 | 05:15 PM
  #35
rdeezy78's Avatar
I'm definitely interested. Now just gotta save up to get mines.
Old Nov 24, 2008 | 05:26 PM
  #36
Blind-Fashion's Avatar
Originally Posted by extralargenog
Im getting a set from Chris at Xenocron and willbe making the switch from my Precision 1000s...
HELLLOOOOOOO 60 PSI base pressure!!!!!!
Lol your full of it!
Old Nov 24, 2008 | 08:13 PM
  #37
extralargenog's Avatar
No... Im going to run them. ALready talked to Chris, actually he approached me with a DEAL on them. My 1000 precisions are on the block....
No Bullshit
Old Nov 26, 2008 | 09:51 AM
  #38
alpha's Avatar
I have four more sets of these injectors on the way. See how they do on these others car but I fully expect them to do the same
Old Nov 26, 2008 | 10:28 AM
  #39
tony1's Avatar
They only work on Hondas
j/k, before anybody freaks out!
Old Nov 26, 2008 | 10:39 AM
  #40
alpha's Avatar
Damn. So that is why this damn Subaru wont make any powa!!! </joke>
Old Nov 26, 2008 | 11:37 AM
  #41
EARLdaSQUIRREL's Avatar
official honda whore
read a couple reviews from vw owners and some werent very good... but it seems they are A++ for us so far
Old Nov 26, 2008 | 05:48 PM
  #42
tony1's Avatar
Any links? I'd be interested to hear what their problems were, I can almost promise the problem has nothing to do with the injector. Probably idiots trying to run them on 500cc reflashes. lol I did a set last week in a 650whp VR6 VW with a POS Haltech E6K that usually won't idle anything over a 750cc injector or so and they ran better than the 650's that were in it. That's not even running sequential.
Old Nov 26, 2008 | 05:59 PM
  #43
ABK's Avatar
ABK
vw suck horribly............ I can't wait to put those in a car and do some e85 tunning, too bad winter is starting. Last time I tried precision 1000cc injectors I was ripping my hair out and after 3 hours of trying to get them to idle consitantly I pulled them out and put 525cc back in. Thanks Tony
Old Nov 27, 2008 | 10:10 AM
  #44
im not on my home computer right now, but when i get back i will try to find the posts, i imagine it had to do with tuning and not the injectors but i will still try to find the posts
Old Nov 28, 2008 | 08:29 AM
  #45
alpha's Avatar
Exactly. I'm 99% sure it is a tuning issue
Old Nov 28, 2008 | 03:15 PM
  #46
Axix24's Avatar
I just ordered some from tony and they are bad-***...
Old Nov 28, 2008 | 08:48 PM
  #47
tagperformance's Avatar
This is an interesting thread considering that bosch does not make a high impedence 1000cc saturated injector. I talked to a guy at sema by the name of clayton Lindgren, who is the bosch mechanical engineering product/technical manager he said he came across a thread on this forum and called the office down in manufacturing and inquired about these injectors because he didn't know anything about these injectors. I was also told that he wouldn't recommend running the pressures that you are running them at. Also is there a reason why you removed the part numbers on them?. If anyone has any questions i will gladly post his number here.
Old Nov 29, 2008 | 10:21 AM
  #48
sewell94's Avatar
They're a modified bosch injector.
Old Nov 29, 2008 | 05:26 PM
  #49
spoolin turbo s's Avatar
if you had a tune with 1000cc peak and hold injectors and swapped to these would you need a new tune?
im interested in what vw guys are saying as well because im on vwvortex about ill day long and haven't seen anything about these
Old Nov 29, 2008 | 05:59 PM
  #50
tony413's Avatar
yes search for tony1's thread about these its like 10 pages long and filled with details
