injector size question
Old Jan 14, 2010 | 10:35 AM
mikej94civex's Avatar
Default injector size question
will 360cc injectors be sufficient for an 8psi build, with walpro fuel pump and for now, stock
fuel rail and injectors...
btw i had dsm 450's but sold them cuz i needed money, i found a deal on brand new 360's off ebay
idk what brand...j/w wonderin if 360's will b suffiecient.
Default Re: injector size question
stock fuel rail and regulator***
Old Jan 14, 2010 | 10:53 AM
zedron's Avatar
They will be. I have a set of RC 750CC injector for sale. They will be more than enough. I would recommend some type of FPR. B&M makes one for $30 or so that use a stock FPR modified. Also get a FP gauge that sits on top of fuel filter.
Old Jan 14, 2010 | 11:29 AM
the brand is 'denso'
they have 360cc and also 390cc, only about $20 difference, so which ones should i get?
888-639-1965
Old Jan 14, 2010 | 11:30 AM
zedron's Avatar
How much are they asking may I ask?
Old Jan 14, 2010 | 11:56 AM
$130 shipped, also i am gettin an aem fpr and ruel rail...how do i got about mounting a gauge on the filter tho?
Old Jan 14, 2010 | 12:29 PM
zedron's Avatar
They come with a specially designed banjo fitting to replace the current one. They come with instructions. Very easy to do, less than 10 minutes.
http://www.thepartsbin.com/sitemap/b...uge~parts.html
Old Jan 14, 2010 | 12:35 PM
dpetro1's Avatar
you cannot pick injectors based on 8psi. you didnt give any details on the setup, most importantly whp goal and fuel type. help us help you.
in general i would say 360cc injectors are good for maybe 250whp on gasoline. you will need to mind your duty cycle closely
Old Jan 14, 2010 | 01:08 PM
my bad, i plan on no more than 175-205whp... i was told my stock 240s could handle that w/ a fpr and fuel pump but i don't wanna take any chances..
Old Jan 14, 2010 | 03:30 PM
dpetro1's Avatar
i dont think the 240s would do 200wp especially on a boost engine with a higher bsfc. 360's might work on such low pwer. you could bump the pressure a bit to help out if needed
Old Jan 14, 2010 | 03:44 PM
i'm just gonna run the 390s to b safe, unless anyone reading this has some 450s for less than $100 shipped in working condition...
JWhonda_ride
Jun 29, 2008 08:54 PM
K-Spec
Oct 25, 2006 02:28 PM
squale
Feb 2, 2006 02:53 PM
ka-nife_
Aug 21, 2005 10:46 PM
