Injector size question
Old Oct 9, 2004 | 12:51 PM
virusiidx's Avatar
Default Injector size question
how can u tell what injector size you have by looking at them? I have 2 sets but don't know the size and if they're rc's or not.
Old Oct 9, 2004 | 01:51 PM
lanojp1's Avatar
Default Re: Injector size question (virusiidx)
RCs will say RC right on them, and mine have it printed on the bottom in white what size they are...
Old Oct 9, 2004 | 02:14 PM
adseguy's Avatar
pic?
Old Oct 9, 2004 | 03:46 PM
virusiidx's Avatar
Old Oct 9, 2004 | 04:32 PM
Alstare's Avatar
The first picture is 1st gen DSM 450cc injectors.
The second pic no idea, but judging by the blurry view of the tips through the plastic they appear to be aftermarket, but not really sure...
Old Oct 9, 2004 | 04:57 PM
hondaguyef's Avatar
Default Re: Injector size question (Alstare)
The 1st set are Blue top DSM 450cc's
The 2nd set looks like Supra injectors not sure on the size though. I saw some in a thread a while back and they looked similar.
Phil
Old Oct 9, 2004 | 06:22 PM
RotiEatter's Avatar
Ditto
Default Re: Injector size question (hondaguyef)
2nd set of injectors look exactly like the set of 440cc Lucas injectors i got from camp1320.com
Old Oct 10, 2004 | 01:46 PM
virusiidx's Avatar
thanks for the replies, I just need some 440s, anymore feedback?
Old Oct 10, 2004 | 05:44 PM
virusiidx's Avatar
Delphi / Lucas
42 lb / hr. '009' Disc Injectors
Part Number Delphi 01D030B (Lucas old 5208009, Lucas New 621031)
Static Flow Rate: 42.29 lb/hr @ 43.5PSI (300kPa) or 320gm/min
Dynamic Flow Rate: 9.96 gm/pulse - 2.5ms pulse width and 10ms repetition rate
Coil Resistance: 15.9 Ohms / High Impedance / High-Z (No ECM driver modifications required)
I just found that information using the serial code i found on them. But what cc are these?
Old Oct 10, 2004 | 09:43 PM
virusiidx's Avatar
bump?
Old Oct 11, 2004 | 08:40 AM
virusiidx's Avatar
anyone? still need info
Old Oct 11, 2004 | 08:45 AM
pngfolife's Avatar
Default Re: (virusiidx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by virusiidx &raquo;</TD></TR><TR><TD CLASS="quote">Delphi / Lucas
I just found that information using the serial code i found on them. But what cc are these?</TD></TR></TABLE>
Convert the lb/hr into cc/min.
Old Oct 12, 2004 | 08:02 AM
virusiidx's Avatar
thanks, did that and they're 440's.
another question, would these fit on my b18b1?
They are lucuas injectors, do they need any modifications, or do they plug right in. thanks.
Old Oct 12, 2004 | 12:24 PM
virusiidx's Avatar
bump
also are these peak and hold or saturated? (the bottom pic, lucas 440s)
Old Oct 23, 2004 | 05:36 PM
WitchHunter's Avatar
Multiply the lb/hr by 10.5 to get cc/min.
Here's a handy calculator http://www.witchhunter.com/injectorcalc1.htm
They are a saturated injector due to the high resistance (15.9 ohms).
Gordon
WitchHunter Performance
Fuel injector cleaning & flow testing service
Perfourmance
Jan 14, 2006 02:45 PM
DD_JonnyLee
Sep 23, 2003 02:57 PM
Crisgo
Apr 9, 2003 04:32 PM
