Injector size question
The first picture is 1st gen DSM 450cc injectors.
The second pic no idea, but judging by the blurry view of the tips through the plastic they appear to be aftermarket, but not really sure...
The 1st set are Blue top DSM 450cc's
The 2nd set looks like Supra injectors not sure on the size though. I saw some in a thread a while back and they looked similar.
Phil
Phil
Delphi / Lucas
42 lb / hr. '009' Disc Injectors
Part Number Delphi 01D030B (Lucas old 5208009, Lucas New 621031)
Static Flow Rate: 42.29 lb/hr @ 43.5PSI (300kPa) or 320gm/min
Dynamic Flow Rate: 9.96 gm/pulse - 2.5ms pulse width and 10ms repetition rate
Coil Resistance: 15.9 Ohms / High Impedance / High-Z (No ECM driver modifications required)
I just found that information using the serial code i found on them. But what cc are these?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by virusiidx »</TD></TR><TR><TD CLASS="quote">Delphi / Lucas
I just found that information using the serial code i found on them. But what cc are these?</TD></TR></TABLE>
Convert the lb/hr into cc/min.
Multiply the lb/hr by 10.5 to get cc/min.
Here's a handy calculator http://www.witchhunter.com/injectorcalc1.htm
They are a saturated injector due to the high resistance (15.9 ohms).
Gordon
WitchHunter Performance
Fuel injector cleaning & flow testing service
Gordon
