injector size
Old Jan 29, 2005 | 03:33 PM
SILVIC00's Avatar
Default injector size
would it be better to go alittle bigger than needed when buying injectors so they are not running at a full duty cycle and so i can upgrade to a bigger setup down the road or buy the recommended size now and buy bigger later when needed?
Old Jan 29, 2005 | 03:45 PM
T4eg's Avatar
Default Re: injector size (SILVIC00)
id say go bigger. So you wont run out of injector with your goals/setup. Plus u can always want to make more power later
Chris
Old Jan 29, 2005 | 03:54 PM
SILVIC00's Avatar
Default Re: injector size (BlueHatch00)
so 550s over 370s
Old Jan 29, 2005 | 04:03 PM
tepid1's Avatar
Yes. I made that mistake too. I bought 440cc when I really could use 550cc
Old Jan 29, 2005 | 04:21 PM
PrettyLude's Avatar
Default Re: injector size (tepid1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueHatch00 &raquo;</TD></TR><TR><TD CLASS="quote">id say go bigger. So you wont run out of injector with your goals/setup. Plus u can always want to make more power later
Chris</TD></TR></TABLE>
Old Jan 29, 2005 | 05:13 PM
ProjectDarkBlack's Avatar
Default Re: injector size (PrettyLude)
what power level do 440`s run out hit full duty cycle, any ideas?
Old Jan 30, 2005 | 09:28 PM
hurleyboarder21's Avatar
Default Re: injector size (ProjectDarkBlack)
with math, they are supposed to run out at i think 300 crank hp @ 80% duty cycle at i forget what fuel pressure ( i think 43psi or something). i think u can go to RC's website and they have all the calculations u need. just plug in your numbers.
fknfast
Mar 14, 2011 03:39 AM
turbo_b16_ex
May 6, 2006 04:23 PM
s2kkid
Jul 13, 2005 04:59 AM
sinatra
41
Aug 7, 2004 08:01 AM
pip9
May 12, 2004 03:45 PM
