injector question
ok, I am turboing my car over the winter...I will keep my stock internals on my B18C5. I am goin to run a inline pro head gasket to lower my compression. I am using a vafc to tune with a fmu....what size injectors will I need to run 8psi and what should I look for my ratio to be on my FMU?
You can run your stock injectors with a 12:1 FMU and an inline pump at 8lbs of boost, but it's not the best thing to do because of the high fuel pressure. If you don't already have an FMU or inline pump, you can run some DSM 450s with the AFC, and it'd be much better than the 12:FMU/stock injector setup.
If you run the VAFC hack, you will need new injector clips and a resistor pack. I sell 4 OEM Honda clips and an OEM Honda resistor box for $35 shipped for the pair.
Sonny
Sonny
u could also use some rc 310's with your 12:1 thats what i did, and was good for like 9psi. Their actually for sale if u want them...i had to get bigger ones. $230shipped if interested. i only used them for 2 months. Jtsintegra@aol.com
