injector question
Old Oct 2, 2009 | 02:18 PM
chrisfromsrq's Avatar
Default injector question
just wondering. will stock injectors be ok for running 8psi on a b20
Old Oct 2, 2009 | 05:16 PM
non-VTEC's Avatar
Default Re: injector question
no
Old Oct 2, 2009 | 05:50 PM
not at all?
Old Oct 2, 2009 | 05:51 PM
E85B18's Avatar
Kinda depends on the turbo, but no. I wouldnt do it!
Old Oct 2, 2009 | 05:54 PM
its a gt28rs. will they hold up for alittle bit at least? untill i get some money to buy some injectors?
Old Oct 2, 2009 | 06:11 PM
what would the best injectors for me be? i have a b20 running 8lbs of boost. should i get low or high impendence? someone help me out
Old Oct 2, 2009 | 06:13 PM
NonovUrbizniz's Avatar
Loved
lol... the injectors will probobly hold up fine... it's the engine staying together running that lean I'd be worried about...
after you get the money for the injectors how are you going to pay to have it tuned???
Don't turbo your car till you can afford the parts... 200 for injectors is better than 1000 for a new long block.
Old Oct 2, 2009 | 06:15 PM
Loved
as far as injector size it's more about HP than PSI. 8 psi on that turbo and 8 psi on a different turbo can yield two entirely different results.
Chances are you'd be ok with DSM450's or similar... if you ever plan on uping the boost though you might as well get bigger injectors now.
Old Oct 2, 2009 | 06:16 PM
what cc should i be lookin for and should ibe looking for low or high impendence?
Old Oct 2, 2009 | 06:44 PM
TehGhett0P1mp's Avatar
You SHOULD be reading the faq it sounds like you really dont know what you are doing. Injector sized is based on HP goal not PSI.
Old Oct 3, 2009 | 04:47 AM
my hp goal is around 200 since the b20 is 126hp stock
Old Oct 3, 2009 | 05:57 AM
my buddy said he would sell me some 450cc injectors for 50buck and they are plug in play. i dont need a resistor box. is this true? can bigger injectors be run without a resistor box?
Old Oct 3, 2009 | 07:20 AM
Loved
You should really just search...
What kind of injectors?
What OBD are you running?
Answers to every question you've asked are ALL OVER this forum.
Old Oct 3, 2009 | 07:26 AM
i am running obd1 they are dsm450 high impendance
Old Oct 4, 2009 | 12:35 PM
bump
Old Oct 4, 2009 | 01:26 PM
E85B18's Avatar
A lot of people are running dsm injectors. To run 8 psi on any turbo you will need something other than stock. Whatever you get, just get it tuned
Old Oct 4, 2009 | 01:33 PM
im trying to find injectors that i dont have to wire in a box. i dont no much about injectors. my friend is helping me with the build. i just need to no what to search for.
Old Oct 4, 2009 | 04:19 PM
TheShodan's Avatar
Moderator
That's a problem, as DSM 450cc injectors are low impedence which require a resistor box.
jestin91
Feb 10, 2013 08:40 AM
jamesfawcett
Apr 13, 2010 01:33 AM
B18 rider
Aug 8, 2008 10:51 AM
Project_DX
16
Jul 30, 2006 08:09 AM
kaneda3
Dec 30, 2002 12:18 PM
