injector question
Old Nov 15, 2006 | 10:32 AM
90Rexx's Avatar
Default injector question
Hey guys im running a custom turbo setup that will be using a turbonetics T3 turbo running low boost (5-6 lbs). its a 1990 crx SI d16a6.My question is WITHOUT tuning at all...can i plug in dsm injectors and will they work? If not will oem injectors from my d16a6 be enough for NOW?
Old Nov 15, 2006 | 10:36 AM
BoostedEG6's Avatar
Default Re: injector question (90Rexx)
oem will be fine.... do not boost on it though or you will go lean and have the chance of blowing your motor.........
If you plug your DSM injectors in you will have to change the correction factor for them
Old Nov 15, 2006 | 10:37 AM
aaronISthrowed's Avatar
Plugging in any other injectors and not tuning will not work. Just keep in your oem ones and don't go into boost.
Old Nov 15, 2006 | 10:48 AM
pheurton-skeurto's Avatar
its still just pure death to have boost there and not have the car tuned...leave the charge pipes disconnected for safety on this.
Old Nov 15, 2006 | 10:50 AM
BoostedEG6's Avatar
Default Re: (pheurton-skeurto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pheurton-skeurto &raquo;</TD></TR><TR><TD CLASS="quote">leave the charge pipes disconnected for safety on this.</TD></TR></TABLE>
DO NOT DO THAT!!!!! you will over spin the turbo causing damage to the turbo itself..... if you do anything do not put the turbo on untill you are ready to tune
Bazza
Nov 16, 2007 08:34 AM
The DX Rex
Dec 28, 2004 07:25 PM
b18c1wes
Oct 2, 2004 05:45 AM
jdm.ej
Jun 23, 2004 11:10 PM
ZygSpeed
Jan 2, 2002 09:44 AM
