Injector HP question
Old May 26, 2007 | 09:36 PM
DrivinVtec's Avatar
Default Injector HP question
I got dsm 450's..how much whp are they good for on a h22 with a t3/t4? if im lookin to hit 400whp what size should I get. Thanks
-George
Old May 26, 2007 | 10:52 PM
da_dude's Avatar
The 450s will be too small for your horsepower goal. Get some 750s instead.
Old May 27, 2007 | 12:14 AM
DrivinVtec's Avatar
what you think the 450 would be good for?
Old May 27, 2007 | 12:20 AM
boostega's Avatar
Default Re: (DrivinVtec)
i ran the same injectors for my 210 hp set up and im doing up a whole new set up, built and boosted and will be looking at 300+ and i have 650cc. if your looking for that much you will deff need bigger
Old May 27, 2007 | 12:30 AM
DrivinVtec's Avatar
ok..i understand I need more for 400whp. but what will 450's do?
Old May 27, 2007 | 12:35 AM
uglyasscivic's Avatar
OMG!!! here. figure it out.
http://www.rceng.com/technical.htm
Old May 27, 2007 | 12:39 AM
DrivinVtec's Avatar
Im good with that...not good with math
Old May 27, 2007 | 02:12 AM
SD_Lurker's Avatar
HT White Ops
(400HP / 4inj) 100HP per Injector
(100HP X .60 B.S.F.C.) 60LBS/HR
(60LBS/HR / .80% Duty) 75 LBS/HR Static Flow Rate
75LBS/HR X 10.50 = 787.5 cc/Min Static Flow Rate required.
750's should be just fine.
Old May 27, 2007 | 02:51 AM
boostingisfun's Avatar
i ran the dsm 450's in my stock gsr turbo and was able to get 343 whp. nobody ever told me that i was maxing them out but im sure it was close. got a whole new build going now with 750's though
Old May 27, 2007 | 10:34 AM
DrivinVtec's Avatar
Default Re: (boostingisfun)
thank you..i was just wondering.
Old May 27, 2007 | 10:35 AM
DrivinVtec's Avatar
Default Re: (SD_Lurker)
hey thanks. where did you get the 10.5 from in the last section?
Nikademo
Apr 22, 2010 01:46 PM
rkostone
Mar 28, 2006 11:20 AM
civic_sc
Nov 10, 2005 10:24 PM
ISawUL00k
Nov 23, 2004 10:05 AM
