Info on Greddy Blue box...
check my Thread on it
https://honda-tech.com/zerothread?id=995844
should be the same wiring for sohc vs dohc
will the blue box work with my 99 civic stock injectors (240cc)??? someone says yes and someone says it won't because its pre-set to be used with 310 injectors.
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
if you get a Greddy Blue box from the SOHC kits, it's calibrated for your stock 240cc injectors. That's what I'm running on my setup right now.
boostincoupe
May 20, 2003 03:29 PM
