important question about turbo and cams
Old Jun 27, 2003 | 03:29 PM
Nextelbuddy's Avatar
Default important question about turbo and cams
my current setup is b16 with jdm 96 type r cams. i am going turbo in 2 wwke. and i was told that i shoudl put my old b16 cams back in because the type r cams will cause too much lift for turbo and it is just safer with b16 cams. is this tru? do i need to run b16 cams instead of type r cams with turbo?
Old Jun 27, 2003 | 03:34 PM
93LSivic's Avatar
Default Re: important question about turbo and cams (nextelbuddy)
Not that they have too much lift. They have too much duration. You want high lift in turbo apps, but short duration. I would suggest gsr cams.
Old Jun 27, 2003 | 03:35 PM
Default Re: important question about turbo and cams (93LSivic)
so basically i cant use my type r cams with turbo?
Old Jun 27, 2003 | 06:51 PM
anyone know if i can use the type r cams in my b16 with a t3/t4 setup running at about 7-9 psi?
Modified by nextelbuddy at 1:40 PM 6/28/2003
Old Jun 28, 2003 | 12:40 PM
bump
Old Jun 29, 2003 | 04:26 AM
osbock98's Avatar
you can but with the longer duration your intake and exhaust valves could over lap and you would loose boost in the cylinder.
Old Jun 29, 2003 | 04:59 AM
toxicshit's Avatar
you will push boost from intake directly into your exhaust header.
use your stock B16 Cams they are less agressive.
or try to find something with a higer lift en a shorter duration.
Old Jun 29, 2003 | 05:48 AM
na4doorgsr's Avatar
Default Re: (toxicshit)
what cams would be best for a 98 ls motor?what do you think is the best kit for that motor and is 70k miles safe to turbo or should it get a new bottom end?
OrangeTeggy
Jun 5, 2010 01:28 PM
GarretCRX
Mar 22, 2007 11:13 AM
GWInquisitor14
Sep 7, 2005 06:25 AM
B16CRXT
Oct 24, 2003 03:16 PM
4ghatch
Jan 30, 2003 05:24 PM
