impendence and resister box. bad >>??
if the stock honda ecu is a high impendence ecu driver, and you run a resistor box to run low impendence injectors.
does this cause the injectors to burn out faster ?
i guess the question is, if you could get high or low. should i go with high since that's what the car is made for. or does hondata recalibrate the signal..
platinum.
platinum.
Drawbacks of? You're just lowering the current draw of the injectors so as not to cook the drivers. Once the current runs through the resistor box, it's no different than it would normally be with saturated injectors. Remember, Honda's ran resistor packs back in the day..
yea they ran them back in the day, but i thought the ecu knew they were low impendence.
why would they have the ecu run high, and then use a resister box to make them low.
platinum.
platinum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 »</TD></TR><TR><TD CLASS="quote">yea they ran them back in the day, but i thought the ecu knew they were low impendence.
platinum.</TD></TR></TABLE>
The ECU didn't "know" anything, the drivers were the same, Honda just used the pack to lower the draw. Why? I guess P/H injectors were cheaper?
Difference in waveforms between saturated and P/H injectors (Tech Note #8).
FYI: P/H injectors can control fuel delivery a little more precisely than the saturated variety.
blackntegra
Oct 29, 2006 11:49 PM
MysteryWagon
Jun 15, 2005 09:35 PM
