IHI t25 on a D15b
Old Jul 3, 2004 | 09:19 PM
Rev-Olution's Avatar
Default IHI t25 on a D15b
I was looking at getting an IHI T25 watercooled turbo for the d15...I was wondering a few things..Compressor side is a .4 a/r, and the hotside is a .52..says it can handle up to 225hp, and boost up to 12psi.
-Does it matter if it is watercooled? Like will it work?
-It has a 3 bolt flange, and i am planning on using a CX manifold...will it work ok as long as i get an adapter plate to match the bolt pattern?
-Has anyone used this turboi, or one like it?
Old Jul 3, 2004 | 09:32 PM
beepy's Avatar
Default Re: IHI t25 on a D15b (Rev-Olution)
Is this the turbo?:
Subaru IHI RHB5
If so there is no reason to try to figure out all of those weird flanges. You can get a Garrett T-25 or a Mitsubishi TD05 or an RHB5 from a non-Subaru engine with a square flange and it will be nearly the same turbo.
This one is .40/.52, and the Garrett and DSM models are .48/.49, which should perform the same.
The watercooling is more common than not and easy to hook up and use. And I would personally recommend it, because then you don't have to worry about turbo timers and other devices to keep your oil from frying.
Old Jul 3, 2004 | 09:39 PM
i was looking at this turbo mainly because of its price...My shop here in town wants $500 for a USED wrx T25!!lol..I found a few others further down the page from sr20's...but thought i would ask about this one since i wasnt familiar with it.
Thank you for your help man
that-guy
Welding / Fabrication
10
Jan 2, 2012 06:10 PM
denraweb
Feb 22, 2008 06:20 AM
RubenPrelude
Feb 21, 2008 07:33 AM
Smokinsax
Oct 13, 2003 10:34 PM
