ignition map
Old Nov 18, 2006 | 12:30 PM
golf-2's Avatar
Default ignition map
i have d16z6 , t3/t4 57 trim , 750 injectors , safc
want to hit 400hp but i miss the right ignition map for this
i am using crome, well if anyone have the map or the bin file for about 29 psi, plz post it
Old Nov 18, 2006 | 01:21 PM
morgan@synapse motorsport's Avatar
why are u using crome and an safc?
is the motor built?
Old Nov 18, 2006 | 01:33 PM
adseguy's Avatar
Default Re: ignition map (golf-2)
just put 26 degrees in at 20-29PSI...it'll be fine.
Old Nov 18, 2006 | 01:45 PM
chasemyhonda's Avatar
B A N N E D
why chance your hard work and money on a hunch.. take it to get tuned. just because someone has this setup and runs this tune.. that doesnt mean that your motor will like the tune
Old Nov 18, 2006 | 10:39 PM
golf-2's Avatar
Default Re: (blindingxenon)
well, the story that i already charged this engine before with stock internals and the safc with 440 , i think i reached 200 hp at 10 psi, don't sure because there is no dyno in my country
i just bought vitara pistons and tt rods beside blockguard and will built it and orderd for 750cc and 3 bar map sensor (i think this enough to reach 350-400) right??
but the problem is in the ignition time, i have the eprom and burner, but i miss the right map,plz if anyone have the map for 29 psi,just post it
thanx
Old Nov 18, 2006 | 11:24 PM
B A N N E D
im just saying that just because someone had good luck with a tune for this engine and this much boost. doesnt mean that your engine will like it... your in a different county.. so your elevation, temperature, humidity would would either be really bad or too conservative for your liking
Old Nov 18, 2006 | 11:29 PM
golf-2's Avatar
yes i am with u blindingxenon , there r many things that will be different from setup to other but i want to reach a good power after this lot cost of money
thanx
Old Nov 19, 2006 | 07:14 PM
boosted k20's Avatar
Default Re: ignition map (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">just put 26 degrees in at 20-29PSI...it'll be fine.</TD></TR></TABLE>
werd. throw in 30* timing and see what it does........
but seriously, get on a dyno and tune out the ignition curve. if ur gonna tune on race gas then start off with timing around 18* at around 15 psi. add/lower timing ans see if the tq curve increases or decreases. do that for the entire psi range that u r tuning for. no one is gonna give u a *PERFECT* timing map, u gotta tune it urself or pay someone to do it
_Justus
Engine Management and Tuning
Apr 18, 2013 02:08 PM
RACEPAK
Jan 18, 2012 01:04 PM
tobster
Sep 18, 2011 03:56 PM
projectjazzmine
Jun 10, 2008 09:38 AM
redteg87
Aug 11, 2003 08:05 AM
