id1000's with resistor box?
Old Feb 8, 2010 | 08:49 AM
jne's Avatar
jne
Default id1000's with resistor box?
i just finished browsing through our sponsors marketplace for a injector upgrade. came across a set of id1000, problem is the ad states that its high impedance/satured so they require NO resistor box. but im currently run dsm 450s and already have a resistor box installed. would they still work with a resistor box, and if so will it cause any harm? thanks!
Old Feb 8, 2010 | 09:02 AM
HRTuning's Avatar
Default Re: id1000's with resistor box?
Remove the resistor box.
Old Feb 8, 2010 | 09:03 AM
twkdCD595's Avatar
No they will not work properly with a resistor box, you would need to remove it.
I had one for instance on my accord from the factory unlike most civics and integras. So I had to do away with one to use the ID1000's.
It is a very simple fix if you dont want to cut into the harness agian. Cut the plug off the resistor box side (leave some short wire tails), strip them back a bit, and then jumper/ solder all the wires together. Plug in the jumper connector you just made and done.
Old Feb 8, 2010 | 09:45 AM
jne's Avatar
jne
sounds good! thanks for the input guys.
Old Feb 8, 2010 | 10:23 AM
jdm inc's Avatar
x2 I had to remove my resistor box also
Jap_Spec_Imports
Mar 15, 2009 01:22 PM
the.hamburglar
Jun 14, 2008 11:26 PM
avotegra
Apr 6, 2007 11:57 PM
SolAssassin
Jul 3, 2006 03:12 PM
dwilson
Mar 21, 2002 03:38 PM
