I need some help.
Old May 22, 2007 | 04:00 PM
2000r#0283's Avatar
Default I need some help.
My brother has a greddy kit on his em1. We've been noticing some oil coming out of the BOV. The old motor was shot so we put in the new motor and we thought it was just from the old busted one. So we cleaned all his piping and intercooler, so we checked it to today and found some more oil. So we check where the catch can hooks up and it was dry, the oil was coming from the turbo itself. Which makes me think the seals are bad. What do you think?
I don't know **** about turbos and all that good stuff. What I was wondering was what size flange is on the 18g? Is it a t3 or a t2? What is another good size turbo with a internal wastegate that will bolt to his flange? We are upgrading later to a t3/t4 with a external wastegate in the future but will work now? Thanks for the help in advance.
Old May 22, 2007 | 04:54 PM
1158's Avatar
Did he get the kit new or buy it used? If the turbo is relatively new, you need to figure out why the seal(s) went before you replace/rebuild the turbo or it will just do it again. What does the drain line look like?
Old May 22, 2007 | 05:04 PM
2000r#0283's Avatar
Default Re: (1158)
The kit has be on the car for about 20k+ miles.
Old May 22, 2007 | 05:15 PM
1158's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000r#0283 &raquo;</TD></TR><TR><TD CLASS="quote">The kit has be on the car for about 20k+ miles.</TD></TR></TABLE>
Well if that's the case then the turbo is probably just used up. If you are going to go with a t3/t4 in the near future, I would probably look for a used greddy to hold you over, or get yours rebuilt.
Old May 22, 2007 | 05:32 PM
2000r#0283's Avatar
Is there any other ok sized turbo that will fit that manifold and internal wastegate? Also what size flange is the 18g?
Old May 22, 2007 | 06:17 PM
1158's Avatar
I believe the flange is a t25.
1sickek187
Feb 17, 2009 10:12 AM
JdmH22Acorn
Nov 16, 2005 07:52 AM
lukebohn
Oct 5, 2005 08:01 AM
ThE PiMpiN Co
Aug 18, 2005 11:18 AM
