I need a manifold! InlinePRO users help! Full-size radiator prob
Old Oct 30, 2005 | 05:45 AM
19sec beast's Avatar
Default I need a manifold! InlinePRO users help! Full-size radiator prob
I was looking at the InlinePRO website because I've heard that their manifolds are full sized radiator compatible and they warranty their products.
I'm currently using a fullsized Fluidyne 38mm thick core radiator with a slim fan on the pass. side.
I'm about to turn up the boost (400-450whp) and I'd like to use a better manifold than my Drag manifold and not worry about cracking, boost creep, etc.
I want a good flowing, reliable manifold and want to keep my fullsized radiator while retaining my A/C and P/S.
Can someone help? I would like to find one ASAP.
Old Oct 30, 2005 | 06:17 AM
B18 CYA's Avatar
inline pro manifolds are excellent. only thing i didnt like about mine was that the bolts kept coming loose. i like manifolds where the bolt goes through the flange all the way and u put a nut on the end
Old Oct 30, 2005 | 06:19 AM
Default Re: (B18 CYA)
How do/did you fix that problem? Ever happen again?
Old Oct 30, 2005 | 06:21 AM
nfn15037's Avatar
Default Re: (19sec beast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19sec beast &raquo;</TD></TR><TR><TD CLASS="quote">How do/did you fix that problem? Ever happen again? </TD></TR></TABLE>
Use studs instead of bolts.
Old Oct 30, 2005 | 06:26 AM
Default Re: (nfn15037)
What are the benefits of getting the SS manifold over the cast Iron?
These manifolds will clear a full-sized, thickcore radiator, correct?
Old Oct 30, 2005 | 06:28 AM
nfn15037's Avatar
Yes I have one that clears a Koyo radiator (thicker than Fluidyne) with an SC61.
Old Oct 30, 2005 | 06:39 AM
Awesome! Thanks for your help, it's really appreciated.
Old Oct 30, 2005 | 06:59 AM
JDMs1eeper's Avatar
I have the SS inlinePro mani, most reliable manifold i know of. Fits nice too
Old Oct 30, 2005 | 07:07 AM
Rory Breaker's Avatar
Default Re: I need a manifold! InlinePRO users help! Full-size radiator prob (19sec beast)
You shouldnt have any problem clearing a full size. Make sure your dump tube is angled correctly however, if you use the drag dumptube, it will melt a hole right through your radiator. Youll need to weld an extension to reroute it away from the radiator.
Old Oct 30, 2005 | 07:34 AM
ramrod's Avatar
Default Re: I need a manifold! InlinePRO users help! Full-size radiator prob (Rory Breaker)
the inline pro/blox are very good manifolds.
when compared to the drag the wastegate placement is much better, and i like the overall design over the drag.
i have a brand new blox mani for sale btw
gl on your search
Old Oct 30, 2005 | 07:49 AM
B18 CYA's Avatar
i moved on to the more blingin manifolds. and trust me i tried every bolt there is. maybe its just me and my setup
Old Oct 30, 2005 | 08:32 AM
2LiterTurboSeR's Avatar
I'm trying to sell a log Spoolin Performance manifold. AC and PS compatible, and I can't see why it wouldn't fit behind your radiator. Still new in box...
Old Oct 30, 2005 | 09:55 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA &raquo;</TD></TR><TR><TD CLASS="quote">i moved on to the more blingin manifolds. and trust me i tried every bolt there is. maybe its just me and my setup</TD></TR></TABLE>
Are you speaking in reference to the bolts never staying in? Did using studs not fix your problem after all?
Old Oct 30, 2005 | 12:46 PM
ramrod's Avatar
my friend used studs with star washers to begin with and never had a problem on his blox.
Old Oct 30, 2005 | 03:00 PM
herbalist's Avatar
Default Re: (large farva)
studs + inlinepro mani = excellence, my friend has this setup with a stock gsr radiator and it works great
Old Oct 31, 2005 | 05:57 AM
Default Re: (herbalist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by herbalist &raquo;</TD></TR><TR><TD CLASS="quote">studs + inlinepro mani = excellence, my friend has this setup with a stock gsr radiator and it works great</TD></TR></TABLE>
This is my setup as well, and I dont have any problem with the nuts backing off. Got my studs from Stan, link in the sig below, never had a problem since
Old Oct 31, 2005 | 08:11 AM
s2kdre's Avatar
Default Re: (Rory Breaker)
inlinepro u have to use a studkit from inlinpro its 20 bucks, regular bolts will always comeout
Old Oct 31, 2005 | 09:16 AM
JDM00SI's Avatar
i thought inline pro was ac compatible?
Old Oct 31, 2005 | 07:39 PM
JDM00SI's Avatar
Default Re: (JDM00SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM00SI &raquo;</TD></TR><TR><TD CLASS="quote">i thought inline pro was ac compatible?</TD></TR></TABLE>
or am i wrong....
Old Nov 1, 2005 | 10:26 AM
D@nnY's Avatar
or am i wrong....</TD></TR></TABLE>
they make an ac and non ac.....the difference is which side the compressor side of the turrbo will face....it will fit with a full size radiator you just have to put the slim fan on the front pushing.......the stainless one will not rust up like the cast iron one
Old Nov 1, 2005 | 12:12 PM
b18c198's Avatar
Default Re: (D@nnY)
I too am rocking an inline pro exhaust manifold and I love it....here's a pic for you.. I still have ac in pic but am removing it for a 3 dp and my new SC61 replacement.
[IMG][/IMG]
Modified by b18c198 at 3:53 PM 11/1/2005
Old Nov 1, 2005 | 03:05 PM
JDM00SI's Avatar
ill sell you mine for 450 already tapped for egt....
Steeve_Civic
Jan 30, 2012 11:26 AM
g2turbo
Mar 10, 2009 03:37 PM
19sec beast
Jun 13, 2005 05:31 AM
no2unenolife
Dec 1, 2004 10:48 PM
soon2b
Aug 18, 2004 06:50 PM
