I need help pleazzzz
Old May 19, 2006 | 02:40 AM
driftboy's Avatar
Default I need help pleazzzz
I just did an H22 swap in a civic hach and i have everthing workin just great ..i have worked on a lot of honda motors but never had to mess with a resistor box for the Injectors nom its just plug them back in with you drop a motor in but do you have to have one or can you bypass it and not use one at all ? b/c the INJECTORS will not open if you dont have one ....... i had to repin half the ecu **** anyways b/c some dip **** had them all fucked up i hate people that monkey expletive **** together...... so if some one could help that would be good ....
thanks for you guys time peace
Old May 19, 2006 | 07:21 AM
purpleh22's Avatar
Default Re: I need help pleazzzz (driftboy)
Ask people at Ground Zero or Torquefreaks in Portland (local dyno/Honda shops). You can also search for info on H22 swaps. Also BoostedNW website works with Chrome and street tunes in our area.
Old May 19, 2006 | 03:12 PM
Tactic$'s Avatar
Garage 808 in Eugene.
Old May 19, 2006 | 07:19 PM
boostedblkef's Avatar
Default Re: (Tactic$)
i thought only non obd used resistor box so if your motor/injectors are obd you can wire it up with out it correct me if im wrong though
eruktion
12
Jul 1, 2010 12:24 AM
more3688
Mar 10, 2010 02:57 PM
bigredEF9
Dec 26, 2009 09:33 AM
h22prelude99
Sep 16, 2007 04:36 AM
garyc17
Jul 3, 2006 11:10 PM
