I need help with my Profec B
Old Jun 17, 2002 | 01:50 PM
JMinSi2000's Avatar
Default I need help with my Profec B
I just installed my profec b and now my wastegate is staying open. These are my connections for everything:
Boost solenoid IN: Intake manifold source
Boost solenoid OUT: Top of Tial wastegate
Side of wastegate: Goes to the compressor side of the turbo
Vac line going to controller: Goes to FPR
All these look right?
Old Jun 17, 2002 | 02:35 PM
DRAGLS's Avatar
Default Re: I need help with my Profec B (JMinSi2000)
Boost solenoid IN: Intake manifold source (goes to same source as side of wastegate)
Old Jun 17, 2002 | 02:48 PM
Adi Radoncic's Avatar
On Fire!
Ok here is how I got my profec b setup..
Boost solenoid IN: tial side teed into fpr and goes into black box in
Boost solenoid OUT: top of tial
Vac line going to controller: vacum line off of the manifold again same tee into the line where the fpr is hooked into because the manifold pressure should be the same in that whole hose setup outside of the manifold..
Adi
Old Jun 17, 2002 | 04:52 PM
JMinSi2000's Avatar
Default Re: I need help with my Profec B (newgsr)
I think I have it working now.
IN and side of wastegate are both T'd off of the turbo.
OUT is going to top of wastegate
Controller is going to FPR.
I had the balance set in the middle and the low boost turned all the way down and wastegate didnt open till about 4-5 psi. I'm gonna run that on the street and when we get it tuned Wednesday I'm gonna have the high boost set for 8, if the boost controller ends up working with it like this.
Old Jun 18, 2002 | 09:51 AM
boosted3g's Avatar
Ignore the directions on the profec. Jsut run the seleniod in a series from the compressor to the side port on the wastegate. I dont know why they didnt print that in the instructions cause if you call them up they will tell you to do it this way.
Old Jun 18, 2002 | 10:04 PM
V8 BAIT's Avatar
maybe this is too late but you could try this.(darn profec B toyed with me for 2 weeks before i got it right).
SOLENOID IN= boost source off compresor side of turbo
SOLENOID OUT=top of tial
SIDE OF WASTEGATE=boost source off of intake manifold
even though it seems pointless using 2 different boost sources it got my profec B to give me boost 1200 rpms sooner than when i tee'd off of the same boost source!
Old Jun 18, 2002 | 10:12 PM
Civicdrgrcr's Avatar
From: WTF DC Racer No Way Turbo Washington., DC, USA
Default Re: I need help with my Profec B (v8bait)
I have my Profec B boost controller also. But I am using a
HKS Racing Wastegate.
Same stuff right.
98integralsB18
Jul 25, 2009 07:29 AM
pv2dickman
May 27, 2005 05:59 PM
CoreyR
Apr 11, 2005 07:09 PM
luckypon7
Jul 1, 2003 06:39 PM
blu_si
Oct 1, 2002 04:20 PM
