I got a free turbo from a 91 eclipse.............
FMU, Piping, BOV, DP, Injectors, Turbo Timer, gauges, boost controller, WG (if needed)...manifold, oil feed/return lines, a lot...and some $$$ too...no $$$=no turbo..
Agreed, depending on the amount of boost you wanna run you may want to get an external wastegate as that turbo will at the very minimum run 12 or so psi on that wastegate, and you may want to run lower if you don't have a built engine. An intercooler would also be a must, just for the performance gains.
Jeff
