how is the water pipe in back of block fastened?
Old May 12, 2003 | 10:38 AM
keebler65's Avatar
Default how is the water pipe in back of block fastened?
i'm doing a JRSC install and i had to bend one of the fittings on the water pipe to a horizontal position. i stuck a tool in there and applied downward pressure. nothing happened so i carefully applied a little more, and then all of a sudden the whole pipe turned so that the fitting was pointing downward. my concern though is that i can now turn the pipe by hand easily. did i break loose something that i shouldnt have? (is it going to leak when i start it up?) i've never seen either end of the pipe so i didnt know if it was just a gasket that sealed it or if there are actual threads on either end of the pipe for a nut to secure it. can someone please let me know if i damaged anything or if i need to remove the water pump, etc to tighten whatever is loose? i dont want to complete this install and then have to take it all apart again.
THANKYOU
Old May 12, 2003 | 11:20 AM
b18bturbo's Avatar
Default Re: how is the water pipe in back of block fastened? (keebler65)
that pipe is only held together with an oring on both ends . as long as the oring is in there it should move becuase there is tab flange on it that locks it one location
Old May 12, 2003 | 11:24 AM
keebler65's Avatar
Default Re: how is the water pipe in back of block fastened? (b18bturbo)
ok thats what i was hoping for. i looked in the helms but they didnt really show clearly how it was attached. thanks for the reassurance.
drlagares
Jul 21, 2018 09:20 AM
parsapour
Apr 28, 2018 08:57 PM
NZstan
Apr 16, 2010 09:15 PM
kraig
Jun 6, 2004 12:32 PM
