How to test 4 wire Oxygen Sensor??
Old Feb 12, 2006 | 10:17 AM
dalecrx's Avatar
Default How to test 4 wire Oxygen Sensor??
I am converting from 0BD0 tp 0BD1.
I just wanted to test out my 4 wire oxygen sensor before i do the wiring to make sure it heats up correctly.
I tested it by connecting the 2 white wires to positive and the grey wire to negative on a 12v battery.
it didnt get hot.
I just want to make sure everything works correctly. otherwise ill be looking for faults once its all complete.
Old Feb 12, 2006 | 10:36 AM
I Have an STD's Avatar
wrenchin'
Default Re: How to test 4 wire Oxygen Sensor?? (dalecrx)
just follow the directions on the conversion harness to make sure it works. if u followthe directions, it will work.
Old Feb 12, 2006 | 02:59 PM
DRAGLS's Avatar
the two white wires are for the heater element
the black wire is the o2 signal to the ecu
the grey wire is the ground for the o2.
hook up one of the white wires to a + source
hook up the other white wire to a - source...heater will get hot
Ronan
May 22, 2007 08:48 PM
genocide43110
Dec 12, 2006 02:09 PM
bluez6
Jul 15, 2006 11:41 PM
dalecrx
Nov 21, 2005 12:01 PM
AtomiK_EK
Jun 19, 2003 06:51 PM
