How to Stop a 400hp Civic?
Old Oct 6, 2003 | 05:09 AM
Soon_2b_evil's Avatar
Default How to Stop a 400hp Civic?
Ok i took this from another broad! Sorry but i got to found out myself too.
I mean cuz you know all these 400hp civic we have out there!
Whats some of the best brake setups for the street to stop a monster like this?
Old Oct 6, 2003 | 05:21 AM
civic disobedience's Avatar
Default Re: How to Stop a 400hp Civic? (Soon_2b_evil)
A good set of cross drilled rotors and a good set of carbon pads is perfectly fine. Oh and a parachute would help too
Old Oct 6, 2003 | 05:24 AM
yellowturbo's Avatar
Slotted rotors are the best crossdrilled crack easily...
so with Brembo slotted rotors and Hawks hps to all four corners you shoud be ok !
Old Oct 6, 2003 | 05:48 AM
GaRn's Avatar
Default Re: (yellowturbo)
unless your doin track racing on a regular basis, they both suck.. if you have to turn slotted or drilled rotors, the shops might not do it!! brembo blanks and axxis pads is the best way to go for the street if you dont have money for a brake kit..
Old Oct 6, 2003 | 05:59 AM
turbohappy's Avatar
Autozone rotors, good pads, and good fluid is all you need
Old Oct 6, 2003 | 06:37 AM
boosted hybrid's Avatar
Fastbrakes 11" Wilwood brake kit front
Fastbrakes 11" rear disc upgrade
ITR brake booster/1" master cylinder
I eat the dash at 120mph highway romps when decelerating.
Old Oct 6, 2003 | 06:39 AM
Happyman's Avatar
Default Re: How to Stop a 400hp Civic? (boosted hybrid)
Jeff when you gonna do another dyno day my turbo del sol needs tunnnnnniiiiinnnngggggg
Old Oct 6, 2003 | 06:47 AM
Default Re: How to Stop a 400hp Civic? (eh6turbo)
Probably in December.
Old Oct 6, 2003 | 08:09 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">Fastbrakes 11" Wilwood brake kit front
I eat the dash at 120mph highway romps when decelerating.</TD></TR></TABLE>
what about a 99-00SI brake booster?
Old Oct 6, 2003 | 08:12 AM
GSRswapandslow
Guest
Posts: n/a
brakes?
what are those???
don't those thing slow you down????
WHO WOULD WANT THAT?!!??!?!??!
Old Oct 6, 2003 | 06:25 PM
Happyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">Probably in December. </TD></TR></TABLE>
I'll have to get the new setup ready. You tune AFCHack?
Old Oct 6, 2003 | 06:40 PM
ebp 99 si's Avatar
what kind of brake setups are out that that you can still fit 13" slicks on your car and not have them rub
Old Oct 6, 2003 | 06:43 PM
GSRswapandslow
Guest
Posts: n/a
stick with GSR at best to fit 13"
and you'll need a spacer
11" is nice and all...but it sure ***** you up for drag racing.
Old Oct 6, 2003 | 08:04 PM
ion_four's Avatar
I could obviously search, but...do you need the ITR brake booster to use teh 1" cylinder? I'm planning on using this, front 10.3"(?) re-located to the rear with custom brackets and 11" up front on an EJ. I have cross-drilled Brembo rotors up front (they were really cheap) and GSR rear-discs at present.
Old Oct 6, 2003 | 08:06 PM
Tomek's Avatar
Default Re: How to Stop a 400hp Civic? (ion_four)
an anchor
Old Oct 6, 2003 | 08:22 PM
DIRep972's Avatar
Smarter than you
This is a good thread. upgrading brakes are something I always think about doing but have never done. @ the track u can get away w/ DX brakes or whatever but anyone who gets on it on the street should think about these things. keep the answers comin!
Old Oct 6, 2003 | 08:24 PM
SiRkid's Avatar
Default Re: How to Stop a 400hp Civic? (DIRep972)
powerslot rotors w/ carbotech pads.
great set up for the $$$
unfortunately i dont have it
still stock set up(Si..but w/abs..go canada go)
Old Oct 6, 2003 | 08:31 PM
KStuned's Avatar
Default Re: How to Stop a 400hp Civic? (SiRkid)
This is how I stop my 400 hp civic! Well, I will find out my exact HP numbers on the 25th of Oct. - Honda-Tech dyno day in Auburn, WA. But if it isn't 400hp @ the wheels, it should be damn close.
Old Oct 6, 2003 | 09:16 PM
lazerus's Avatar
Default Re: How to Stop a 400hp Civic? (Hondaddict)
brick walls work phenominally well stopping any car.
Old Oct 6, 2003 | 09:55 PM
BodyKits NW's Avatar
I run big brakes all around.
Old Oct 6, 2003 | 10:14 PM
Unsung's Avatar
Stock with upgraded pads. Slotted/drilled are worse than stock in a lot of cases.
Old Oct 6, 2003 | 10:47 PM
Stu's Avatar
Stu
New User
What does horsepower have to do with stopping? Or are you guys just being fecious? (sp)
Old Oct 6, 2003 | 10:51 PM
lazerus's Avatar
Default Re: (Stu)
the more power you make, the larger your braking components are going to have to be.
Old Oct 6, 2003 | 11:20 PM
bretx0r's Avatar
Default Re: (lazerus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus &raquo;</TD></TR><TR><TD CLASS="quote">the more power you make, the larger your braking components are going to have to be.</TD></TR></TABLE>
when road racing and autocrossing...
everything else stocks fine
Old Oct 6, 2003 | 11:23 PM
DIRep972's Avatar
Smarter than you
Default Re: (Stu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stu &raquo;</TD></TR><TR><TD CLASS="quote">What does horsepower have to do with stopping? Or are you guys just being fecious? (sp)</TD></TR></TABLE>
stock honda brakes aren't really meant to stop from 140. and when u take a car that does 90mph in the 1/4 and make it go 110-140 you gotta be able to slow it down too. especially if its a street car. if u get on it on the street, racing or not, u wanna be able to stop too.
