How safe is the FMU?
What are the downsides of having just the FMU stock injectors and stock fuel pump? I'm running the revhard stage 2 and I'm concerned with the stability of my system.
Just wanted to post,
Dave
Dave
If you dont want to run alot of boost it works fine. Im talking like 7-8 lbs is what I would think is the most you should be running with it. If you want mroe than that you need to invest in a standalone. But 7-8 lbs is fast as it is. A guy on here was in the 12's with an FMU, so it works.
I think they are 240's but I could be wrong. I would keep it at 9 at the very highest. That is 108 psi of fuel pressure right there at 9 lbs. I guess if it is working it shold continue to work, just dont turn it up.
How much would an AFC help?
sorry for the general questions. I want to know more, but not really - IT'S FRIDAY AFTERNOON AND I'M GOING SALMON FISHING TOMORROW! YAY...
Dave
Dave
an AFC would work good to fine tune the fuel, add it where you need it and take it away where it is to rich, i think that with an fmu and an afc, if you have your head on straight you can make your car run pretty good. seat of your pants dyno style!
evan better if you can get ahold of a wideband o2 sensor, then you can dial it in nicely.
Rob
[Modified by rjardy, 7:55 AM 8/10/2002]
Rob
You /HAVE/ to have a high pressure inline pump installed to use the standard FMU fuel system.
Even then, it is not very reliable except for short runs. The insanely high fuel pressure heats the injectors up (takes more amperage to open them) and fuel delivery becomes unpredictable -- This is why so many people blow motors doing high speed runs w/ the FMU.
Dustin
scarey thought... so an inline pump and some new injectors will be better? What injectors do you recommend?
dAve
dAve
[Modified by dlplayboy, 4:58 AM 8/10/2002]
hondaeg8
Mar 19, 2004 08:38 PM
