How reliable is this setup?
Old Feb 20, 2008 | 08:01 PM
HondamanXxX's Avatar
GO GIANTS!
Default How reliable is this setup?
Modified by HondamanXxX at 11:13 PM 4/16/2008
Old Feb 20, 2008 | 08:34 PM
lsvtec300's Avatar
Default Re: How reliable is this setup? (HondamanXxX)
as long as u don't boost to high and have good tunning ur safe
Old Feb 20, 2008 | 09:15 PM
WGFletch4WS's Avatar
as reliable as ur tune
Old Feb 20, 2008 | 09:25 PM
98lude-t's Avatar
Default Re: (WGFletch4WS)
lets say 20psi on it not for long. 10-12 yeah for a while and expletiveen fun...
Old Feb 20, 2008 | 09:52 PM
hellakapps's Avatar
what thicker hg? what brand, i'd go with oem and like already said it's all about the tune
Old Feb 20, 2008 | 10:45 PM
Turbo B18C EJ6's Avatar
Default Re: How reliable is this setup? (hellakapps)
Your also going to needs a bigger fuel pump, walbro 255 will suit your setup fine, also you will need bigger injectors, with a 60 trim you can get 750 sat or 880 peak and hold, however you will need to wire in a resistor box for the 880,s.
Old Feb 21, 2008 | 03:05 AM
tekturbo's Avatar
yOU CAN BOOST HIGH AS YOU WAT LONG AS YOUR TUNER IS GOOD. THATS ALL THAT MATTERS NOT PSI! ,IF ITS PUT TOGETHER RIGHT AND TUNED GOOD ITS RELIABLE AS ANY TURBO CAR ROLLING OFF THE NEW CARLOT.
Old Feb 21, 2008 | 06:29 AM
GO GIANTS!
Default Re: (tekturbo)
Old Feb 21, 2008 | 06:35 AM
morgan@synapse motorsport's Avatar
Default Re: (HondamanXxX)
i wouldnt even bother opening the motor up to put a new HG and head studs in there the stock components are not a weak component in the motor. if you keep your power goals reasonable for the stock motor and maintain it properly there is no reason you cant have a very reliable setup.
Old Feb 21, 2008 | 06:36 AM
GO GIANTS!
Default Re: (mike@synapse motorsport)
Old Feb 21, 2008 | 06:43 AM
Antilag's Avatar
I wouldn't worry about lowering compression. Its fine. Make sure your tune is safe and conservative. 11.0-11.2 under +Map. safe timing. If you want it reliable stay under 13-14psi. I have seen alot of stock motors let go at 20 psi with a safe tune and one hell of a tuner. Put a street ati or fluidampner to give you the extra insurance.
Old Feb 21, 2008 | 08:12 AM
GO GIANTS!
Default Re: (Antilag)
Old Feb 21, 2008 | 09:23 AM
carzntune's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondamanXxX &raquo;</TD></TR><TR><TD CLASS="quote">One more question. What size TB would you guys go with? I know it makes a big difference. </TD></TR></TABLE>
I'd keep the stock TB. At the power level you'll be making, I don't see the need to spend the extra money. Save it for the pump and injectors you'll need.
Jeff gets some great numbers with OEM head gaskets and ARP studs. Squeezed 375whp from my bone stock GSR.
Old Feb 21, 2008 | 04:33 PM
GO GIANTS!
Default Re: (carzntune)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carzntune &raquo;</TD></TR><TR><TD CLASS="quote">Jeff gets some great numbers with OEM head gaskets and ARP studs. Squeezed 375whp from my bone stock GSR. </TD></TR></TABLE>
Oh please tell me more!
Old Feb 21, 2008 | 04:37 PM
.dave's Avatar
i HAS questions ?
Sounds like a hell of a setup. I agree with others and I'd say don't crack open the engine unless you have to.
Old Feb 21, 2008 | 04:45 PM
carzntune's Avatar
Oh please tell me more! </TD></TR></TABLE>
Sent you a PM.
Old Feb 21, 2008 | 07:30 PM
GO GIANTS!
Old Feb 21, 2008 | 07:43 PM
Antilag's Avatar
Tell Jeff to tune you 2 maps with a flip of a switch. 1 map 8-10 psi on pump gas, and 14-15 psi on Race gas for your track days.
Old Feb 21, 2008 | 07:44 PM
GO GIANTS!
Thats pretty cool. never thought of that. Wouldn't he have to tune the car on the Race Gas also?
Old Feb 21, 2008 | 10:11 PM
Antilag's Avatar
Yes.
3gdean
Sep 20, 2014 09:34 AM
killakalipoph
May 20, 2009 09:44 AM
r1ch1e
Sep 11, 2006 07:58 PM
egizzle8
Sep 3, 2004 05:51 AM
TurboB18C1
Oct 11, 2002 05:53 PM
