How to properly Hone?
Old Aug 4, 2002 | 11:23 AM
Ri5e's Avatar
Default How to properly Hone?
I'm in the process of Honing the cylinder walls. And was thinking of buying a Honing device. Which Honing device do you recommend? Also how do you properly Hone the wall?
Old Aug 4, 2002 | 07:31 PM
Ri5e's Avatar
Default Re: How to properly Hone? (BG Boost)
ttt
Old Aug 4, 2002 | 08:12 PM
b18bturbo's Avatar
you need ahone device with a cross hatch pattern. thats all doesnt matter which device just somethign that does that.
Old Aug 4, 2002 | 08:22 PM
Ri5e's Avatar
Default Re: How to properly Hone? (b18bturbo)
Doesn't matter like the angles at which they intersect? Also how do I go about using it? Just move it up and down 2 times?
Old Aug 5, 2002 | 04:31 AM
Ri5e's Avatar
t
Old Aug 5, 2002 | 05:46 AM
CovertFI's Avatar
i would like to know what
bump*
Old Aug 5, 2002 | 08:26 AM
89civic1.8T's Avatar
Default Re: How to properly Hone? (CovertFI)
I wanna know too!!!
Old Aug 5, 2002 | 08:45 AM
turboex's Avatar
Default Re: How to properly Hone? (89civic1.8T)
put the hone in and get a little tension on the springs. then use some ATF and have at it. try maintain a single speed around and up and down.
Old Aug 5, 2002 | 06:28 PM
Ri5e's Avatar
Default Re: How to properly Hone? (turboex)
ttt
Old Aug 5, 2002 | 06:46 PM
DOHCtorJT's Avatar
Crosshatch intersect angle should be between 50 and 60 degrees. This is a general rule, not honda specific.
Old Jul 1, 2003 | 07:03 PM
bluedelsol's Avatar
Default Re: How to properly Hone? (DOHCtorJT)
ok, so how long should you spend on each cylinder? where can you buy a hone with the cross hatch design? and is motor oil ok to use as lubricant?
Old Jul 1, 2003 | 07:10 PM
x2gold's Avatar
Default Re: How to properly Hone? (bluedelsol)
Check these out . It doesn't take very long at all. You must be very careful when doing this though; removing too much material from the cylinder walls = costly machine work (overbore).
Basically you can rent (Autozone, Pep Boys), or buy a honing tool. Honda recommends a medium grit stone which is what most places stock. The tool runs about $30-$40 depending on where you live and can be easily returned/refunded if you plan on doing one engine.
Hope this helps.
Old Jul 2, 2003 | 07:57 AM
bluedelsol's Avatar
Default Re: How to properly Hone? (x2gold)
ok, well some people say to use a flew hone with the ***** on the ends and some say to use the 3 stone hone. so witch one is better? witch is easier to use?
Old Jul 2, 2003 | 08:12 AM
hypa's Avatar
Being that the crosshatch pattern is what helps cut the rings in (for sealing purposes), we don nothing except machine honing. Find a good local machine shop with a honing machine, and give them the $50 to do it.
Why chance it when a machine can do it right, and consistantly for not a lot of cash.
Old Jul 2, 2003 | 08:19 AM
EE_Chris's Avatar
Default Re: (hypa)
.....exactly, stick with the Sunnen (or other honing machine) as hypa suggested.
Old Jul 2, 2003 | 08:24 AM
DaveF's Avatar
Default Re: (EE_Chris)
if you are going to do it by hand ....
stick the hone "bit" on a hand drill....maintaining a constant speed, as mentioned above....move the drill up and down in the cyl walls to get teh cross hatch pattern.....just dont go too far. and try not to stay in any one specific spot for too long. also....dont forget the ATF.
HTH
Old Jul 2, 2003 | 08:26 AM
93LSivic's Avatar
60 degree angle as mentioned in the Helms. I would definetly suggest a machine shop do this.
If your gonna do it yourself, you will want a bore dial indicator.............how do you know if your cylinder walls are not out of round?????????????? You just may need to overbore anyways. Just some insight, take it as you may.
Old Jul 2, 2003 | 10:46 AM
bretx0r's Avatar
strip the block and get it done on a machine
Old Jul 2, 2003 | 01:10 PM
MaxBoost's Avatar
New User
Default Re: How to properly Hone? (bretx0r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bretx0r &raquo;</TD></TR><TR><TD CLASS="quote">strip the block and get it done on a machine</TD></TR></TABLE>
Do that **** right or don't do it at all. I would only do this DIY crap if I was rebuilding my grandma's 8-valve cx motor. But for anything even remotely performance related, please take your head to a machine shop so they can properly bore and hone your block.
Like someone said, you need to know if your block it out of round, or if perhaps sleeves have moved. Having a proper honing machine will make a difference.
ketchup
Sep 29, 2012 10:39 PM
fmx_dbc
Jul 23, 2009 11:28 AM
rice a roni
Feb 14, 2006 08:17 AM
tnord
30
May 28, 2005 07:57 PM
