how much hp will walbro 255 flow for?
Old Aug 26, 2008 | 05:07 PM
got wide's Avatar
Default how much hp will walbro 255 flow for?
just as stated, how much hp will the walbro 255 flow in a boosted application SAFELY? and can any one tell me who makes the in tank mount kit for the double walbro setup?
Old Aug 26, 2008 | 05:44 PM
GT35R_EF's Avatar
Make mine whatever you want
Default Re: how much hp will walbro 255 flow for? (got wide)
https://honda-tech.com/zerothread?id=1346793
https://honda-tech.com/zerothread?id=1202099
(As far as how much it will flow.) ^
And also, full blown motorsports makes the dual in-tank kit.
http://www.fullblownmotorsport...12a5a
^Link to their site. Good luck man, and if you're looking at any more than 500-600 horsepower defenitely stick with an external pump IMO. The only issues I have heard of involving the dual walbros is that if one of the two starts to fail, you wont necassarily know it until it's to late. WHILE an external pump, if it fails will show obvious signs. Good luck
Bseriescivic5's Avatar
i made 600 with my 255 high pressure, anyone else chime in?
Old Aug 26, 2008 | 11:45 PM
B20luda's Avatar
Default Re: (Bseriescivic5)
I ran out just over 500whp h22a NEW walbro HP GE fuel rail and areomotive FPR 1000cc injectors
I think a fuel pump rewire and getting ride of the banjo gayness and stock filter would help alot.
Im going to bosch inline and doing all the above mods as well soon
Old Aug 27, 2008 | 04:28 AM
SPOOLINmatt's Avatar
Default Re: (B20luda)
a little over 600 here on 1000cc's
Old Aug 27, 2008 | 06:42 AM
HiProfile's Avatar
Default Re: how much hp will walbro 255 flow for? (GT35R_EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GT35R_EF &raquo;</TD></TR><TR><TD CLASS="quote">The only issues I have heard of involving the dual walbros is that if one of the two starts to fail, you wont necassarily know it until it's to late. WHILE an external pump, if it fails will show obvious signs. Good luck </TD></TR></TABLE>
And if you run JUST the walbro in-tank, you're SOL if it fails. Since most pumps don't just go from 100% to 0% in 2 seconds, you will not know right away that something is up regardless. In basicly any dual setup - series (booster) or parallel - the one pump will generally have enough to let it idle okay, but will usually be lean under medium-heavy load. The inline setup would probably be worse - if your stock pump will idle fine, and give you fuel for some boost - but then taper off at 2-300whp, or 300-400whp, depending on the pump type.
In short, it doesn't really matter what setup you have - pumps rarely fail if used properly.
Old Aug 27, 2008 | 07:01 AM
totsie7944's Avatar
Default Re: how much hp will walbro 255 flow for? (HiProfile)
I thought there has been some people who have hit 650-670 whp on just a intank Walbro 255 high out put?
Old Aug 27, 2008 | 08:45 AM
purpleh22's Avatar
Default Re: how much hp will walbro 255 flow for? (totsie7944)
I added an inline to my walbro on an H22 @ 465whp and had capacity to spare. Switched to E85 @ 435 whp and ran out of capacity. Currently changing from GT30 to GT35 and using a MagnaFuel 625.
Old Aug 27, 2008 | 09:33 AM
95exdsmkilla's Avatar
Default Re: how much hp will walbro 255 flow for? (purpleh22)
It's really not the pump that max out. It's the stock fuel lines will max out.
Maxd mine @ 620-630sih.
Was not the fuel pump.. was the lines.
1200cc rc injectors
Aeromotive FPR
etc...
Old Aug 27, 2008 | 03:09 PM
got wide's Avatar
Default Re: how much hp will walbro 255 flow for? (95exdsmkilla)
yeah the lines are the next thing on the list. i figure ill run a -8 feed and -6 return. i currently have a single walbro 255 but plan on making 750whp and i knew that pump would do it alone. i really like the aeromotive a1000 sump kit but its a little pricey at around $1600 for the just the sump and pump. is anyone running this setup or have any unbiased knowledge or opinions about it?
Old Aug 27, 2008 | 05:20 PM
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">I thought there has been some people who have hit 650-670 whp on just a intank Walbro 255 high out put?</TD></TR></TABLE>
thatd be pushing it.
i made 540 with 1200's and a little room.
i think it is full blown that makes the dual walbro sender setup. i know t1 has them on his online store.
Old Aug 27, 2008 | 05:31 PM
purpleh22's Avatar
Default Re: how much hp will walbro 255 flow for? (boostedcivicsir)
Heard the MagnFuel is high quality, much quieter, a lot less expensive and will handle well over 1000 hp. I'm using the 625 - it's gear drive and self priming.
purpleh22's Avatar
Heard the MagnFuel is high quality, much quieter, a lot less expensive and will handle well over 1000 hp. I'm using the 625 Tuner Pro - it's gear drive and self priming.
Old Aug 27, 2008 | 06:36 PM
98civicswapped's Avatar
made 500+ on pump gas and 626 on c16 on 1000's
Old Aug 27, 2008 | 07:00 PM
LSTEG96's Avatar
Default Re: how much hp will walbro 255 flow for? (98civicswapped)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98civicswapped &raquo;</TD></TR><TR><TD CLASS="quote">made 500+ on pump gas and 626 on c16 on 1000's </TD></TR></TABLE>
GNARLLY DUUUDE!
now what's your fuel pump setup? (the topic of discussion....................................... )
Old Aug 27, 2008 | 07:17 PM
Default Re: how much hp will walbro 255 flow for? (LSTEG96)
well considering its in a walbro 255 topic then it would be walbro 255, stock fuel lines and 1000's
Old Aug 27, 2008 | 07:27 PM
LSTEG96's Avatar
good point.
Old Aug 27, 2008 | 07:57 PM
tony413's Avatar
what a beat to death ? isnt this posted about 8 times in the FAQ's ???
anyways 1 walbro 255highpressure, good for ~550whp
Old Aug 28, 2008 | 07:47 AM
totsie7944's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">
i think it is full blown that makes the dual walbro sender setup. i know t1 has them on his online store.</TD></TR></TABLE>
Hmm I guess your right, but I could have sworn I've seen guys with stock fuel lines and 1 walbro hitting mid 600's on Jeff's website. I hit 540 whp on pump with stock lines and 1 walbro, but that isn't unreasonable. I guess when I tune on race gas I'll find out..
Old Aug 28, 2008 | 05:22 PM
ralph11sec's Avatar
i tuned a friend made a little over 600 @ 24psi @ gt35 @ 2L using 255HP, 1000RC.
fuel pressure in defi is dropping BIG TIME at the high rpm. yes i was maintaining 11.8-12.0 afr, but fuel pressure is scaring me. so we stopped.
Old Aug 28, 2008 | 06:40 PM
got wide's Avatar
Default Re: how much hp will walbro 255 flow for? (ralph11sec)
http://www.aeromotiveinc.com/products.php?prod=265
so i guess these arent out yet but will be available in sept. looks like a kick *** setup but kinda pricey to not include the pump or filter. are stock gas tanks mild steel? anybody think they might run this sump or have a similar setup?
Old Aug 28, 2008 | 07:19 PM
tony413's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by got wide &raquo;</TD></TR><TR><TD CLASS="quote">http://www.aeromotiveinc.com/products.php?prod=265
so i guess these arent out yet but will be available in sept. looks like a kick *** setup but kinda pricey to not include the pump or filter. are stock gas tanks mild steel? anybody think they might run this sump or have a similar setup?</TD></TR></TABLE>
i think this is much better and for the price its kick ***
yeah thats a dual bosch 044 set-up inside of a fuel sump. $400 for 2 boschs and $120 for a custom sump.
Old Aug 28, 2008 | 08:14 PM
cfwthb_94's Avatar
Default Re: how much hp will walbro 255 flow for? (tony413)
and where do you get one of those?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 &raquo;</TD></TR><TR><TD CLASS="quote">
yeah thats a dual bosch 044 set-up inside of a fuel sump. $400 for 2 boschs and $120 for a custom sump. </TD></TR></TABLE>
Old Aug 28, 2008 | 08:38 PM
tony413's Avatar
Default Re: how much hp will walbro 255 flow for? (cfwthb_94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cfwthb_94 &raquo;</TD></TR><TR><TD CLASS="quote">and where do you get one of those?
you make it of course
the pumps you can buy, they are just regular bosch 044's or you can buy bosch 040's but they with that pump they need to be fully submerged; the 044 can use a sock filter.
the sump is pretty much a regular style sump but has a trapazoid design to fit the pumps nice and snug
Old Aug 28, 2008 | 09:39 PM
Urban_Indian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by got wide &raquo;</TD></TR><TR><TD CLASS="quote">yeah the lines are the next thing on the list. i figure ill run a -8 feed and -6 return?</TD></TR></TABLE>
i am running a -8 feed and a -6 return into the stock FEED line( at the firewall) as a return. There is like a foot of -6 line from the FPR into the stock feed. looks baller and i will be running it on my 700+HP setup
*edit*
thats a fullblown dual fuel pump set-up btw
